1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
9564PC
Background and Identification
Makita is a Japanese power tool manufacturer that was founded in 1915. It is a leading brand of professional-grade tools. This company produces cordless tools, power tools, petrol equipment, and batteries. Their tools range from wrenches and drills to chainsaws, lawnmowers, and angle grinders. An angle grinder is a handheld power tool that uses a rotating abrasive disk to do cutting and polishing work on a surface. These tools are commonly found in machine shops, construction sites, or metalworking projects.
The Angle Grinder 9564PC is referred to by Makita’s website as a mini-grinder, which means that it has a smaller disk diameter of 4-1/2 inches. The smaller size means that this angle grinder is well-suited for more detailed work in removing material and polishing. To use this power tool properly, the operator should be careful to read and follow all safety guidelines and instructions found in the owner’s manual.
Technical Specifications
  • Wheel Diameter : 4-1/2"
  • Overall Length : 12-1/8"
  • Net Weight : 5.3 lbs.
  • AMPS : 13
  • Power Type : Corded
  • No Load Speed : 10,500 RPM
  • Variable speed dial : No
  • Spindle Type : 5/8" - 11 UNC
  • Switch Type : Body grip/paddle
  • Lock-On Switch : No
  • Lock-Off Switch : Yes
  • Bind-Up Control : Yes
Additional Information
Makita - Wikipedia
Angle Grinder - Wikipedia
Product Page
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 95
All Time: 4,626
