1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
4112H
Background
The Makita 4112H is an industrial grinder intended for cutting steel, concrete, and masonry materials with a dry cutting diamond blade. It incorporates 'SJS' technology to avoid kickback when blade jamming occurs. This tool is suitable for a range of applications, such as builders, fire/rescue, maintenance, remodelers, roofers, masons, and pipe fitters.
Technical Specifications
  • Blade Diameter: 12" (305 mm)
  • Arbor: 1" (25.4 mm)
  • Maximum Cutting Depth: 3-15/16" (100 mm)
  • No Load Speed: 5,000 RPM
  • AMPS (120V): 15.0 A
  • Overall Length: 25-1/2" (648 mm)
  • Net Weight: 25.1 lbs (11.4 kg)
Makita 4112H Angle Cutter Model 4112H (MJ)
Makita 4112H 12 Angle Cutter
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 682
