1 Diagram
Documents
Models
MAC2400
Background
The Makita XEC01Z is a cordless 9" power cutter intended for cutting various materials, including concrete, I-beams, steel pipes, rebar, and metal studs. This tool operates on two 18V LXT® Lithium-Ion batteries, eliminating the necessity for engine pull starts, oil/gas mixing, and engine maintenance. Its brushless motor provides 6,600 RPM, and the cutter features a 3-1/2" maximum cutting depth, enabling it to slice through standard residential concrete slabs in one pass. Additionally, the power cutter comes with an integrated water delivery system for OSHA Table 1 Compliance in concrete cutting tasks. The Makita XEC01Z aims to reduce operator fatigue, offer instant starts, and save costs while being suitable for indoor use, tight spaces, and elevated areas. This power cutter is part of Makita's expanding 18V LXT System, a comprehensive cordless tool system that relies on 18V lithium-ion slide-style batteries.
Technical Specifications
  • Battery: 2X 18V LXT® Lithium-Ion
  • No Load Speed: 6,600 RPM
  • Wheel Diameter: 9"
  • Max. Cutting Depth: 3-1/2"
  • Arbor Size: 7/8"
  • Lock-Off Switch: Yes
  • Switch Type: Rear trigger switch
  • Electric Brake: Yes
  • Bind-Up Control: Yes
  • Overall Length: 21-3/4"
  • Net Weight (with battery): 13.7 lbs.
  • Power Type: Cordless
  • Form Factor (LXT): X2
  • Motor Type: Brushless
  • Shipping Weight: 17.42 lbs.
  • UPC Code: 088381-899390
35f3ac70 2395 4713 9d8c 1789477cfc7c XEC01 IM 885786 942
Ee0847a9 0edc 4733 8ca5 5934b9476010 XEC01 PB
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 47
All Time: 786
