Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The MSI GS65 Stealth was a high-performance gaming laptop known for its sleek design and powerful specifications. Originally released in 2019, its blend of portability and performance made it a powerful gaming machine. The laptop features a 15.6-inch display with thin bezels, this is a common point of failure since the outer case specifically around the screen would crack and cause screen issues such as uneven backlighting and light bleeding. The Intel 8th generation features a Core i7 processor and Nvidia's GTX 1070 Max-Q graphics card. It is lightweight compared to bulkier gaming laptops at the time. The GS65 series is also recognized for its customizable RGB keyboard which over time would dim but didn’t affect performance, it also has extensive connectivity options, making it a versatile choice for both gaming and professional use.
Specifically, the 2019 MSI GS65 Stealth Thin 8SG is an upgraded version, featuring Nvidia Turing graphics and a handful of minor improvements. While the addition of Ray Tracing alone did not warrant the steep price of the RTX models, the approximate 20% boost in gaming performance offered those who wished for that edge in FPS shooters and cooler operating temperature thought to be upgraded saw issues primarily with the fans running hot and sounding loud.
Identification
There are a multitude of ways to identify the model name and number. Most MSI laptops have a large sticker just below the keyboard. If not there, check the bottom of your laptop for a sticker. It could also be printed inside the battery compartment.
If you can turn it on, type Help Desk into the search box and that should bring up the app where the model name will be listed on top in red.
If there is no app to be seen, typing System Information will bring up a summary of the laptop's information, including model name.
Otherwise, when MSI logo shows up as the laptop is starting to boot up, keep tapping the "Delete" or "F12" until you the BIOS Setup Utility pop up. This could take several attempts.
Specifications
  • CPU: Up to 8th Gen. Intel® Core™ i7 Processor
  • OS: Windows 10 Pro | Windows 10 Home
  • Display: 15.6" FHD (1920x1080), 144Hz, IPS-Level
  • Chipset: Intel® HM370
  • Graphics: NVIDIA® GeForce RTX™ 2080 with Max-Q Design, 8GB GDDR6
  • Memory: DDR4-2666 | Max 32GB | 2 Slots
  • Storage Capability: 1x M.2 SSD slot (NVMe PCIe Gen3), 1x M.2 SSD Combo slot (NVMe PCIe Gen3 / SATA)
  • Webcam: HD type (30fps@720p)
  • Keyboard: Per-Key RGB Keyboard
  • Communication: Killer Gb LAN | Killer ac Wi-Fi + Bluetooth v5
  • Audio: 2x 2W Speaker
  • Audiojack: 1x Mic-in, 1x Headphone-out (HiFi)
  • I/O Ports: 1x Type-C (USB3.1 Gen2 / DP / Thunderbolt™3) | 3x Type-A USB3.1 | 1x HDMI™ 2.1 (4K @ 60Hz) | 1x Mini-DisplayPort | 1x RJ45
  • Battery: 4-Cell | 82 Battery (Whr)
  • AC Adapter: 230W Slim adapter
  • Dimensions: 357.7 x 247.7 x 17.9 mm
  • Weight: (W/ Battery): 1.9kg
Additional Information
GS65 Stealth Specifications on Official Site
Drivers and Manuals
MSI GS65 Stealth Thin 8SG on Amazon
MSI GS65 Stealth Thin 8SG Review on Ultrabookreview.com
Fix an Overheating Laptop: MSI GS65 - RTX 2080 (Teardown, Thermal Repaste & SSD Upgrade)
MSI GS65 Stealth (8SG)
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 70
All Time: 2,219
