Up to 20% off select tools
Guides
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
MSI GS63VR 7RF
Troubleshooting
For more information and help check out the MSI GS63VR 7RF Stealth Pro Troubleshooting page.
Background
The MSI GS63VR 7RF Stealth Pro is a new gaming laptop from 2017. It has a 7th generation Intel Core i7 processor and a GTX 1060 GPU. Dimensions (WxDxH)mm 380 x 249 x 17.7 mm (15 x 9.8 x .7)in, and weighs 1.8 kg (4 lbs). Is the successor to the 6th Generation and is succeeded by the GS73VR Stealth Pro. Runs on a Windows 10 OS system. Has a 15.6" FHD display that runs at (1920x1080p). It also has a front facing webcam with a rainbow back lit mechanical keyboard. A LAN port, is Wi-Fi and Bluetooth capable, 5x USB ports, 1x SD card reader, 1x HDMI port, 1x Mini-Display port, 2x speakers above the keyboard, a Mic-in port, and a headphone port. Model No: MS-16K2
  • Memory Type: DDR4-2400
  • 2x DIMM Slots
  • 256GB SSD
  • 1T HDD 2.5"
  • A 3-cell Li-Polymer Battery
Identification
To help identify if this is your laptop, look at the sticker on the inside of the device when you first open it. On the bottom cover, look at the Model Number and see if it says MS-16K2.
Additional Information
Author
with
Nicholas Perry
549 Reputation
2 Guides authored
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 83
All Time: 34,844
