Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Logitech Zone Learn wired headset was built with learning in mind. The headset is aimed at allowing schools to easily buy and deploy headsets, making learning easily accessible to children. The headset comes at a low price-point and is designed to withstand typical daily use in the classroom.
Identification
The Zone Learn headset is navy blue with an orange headband pad and microphone. It has a 3.5 mm jack and microphone on the left cup. The headset is on the smaller side since it's aimed at children. Logitech offers both over ear and on ear headset pads, as well as different cable options—USB-A, USB-C and 3.5 mm. The model number can be found under the left ear pad, which twists off. The Zone Learn wired headset has model number (labeled M/N) A00184.
Technical Specifications
Dimensions (H x W x L)
  • On-ear headset (no cables): 156 x 190 x 67 mm
  • Over-ear headset (no cables): 165 x 190 x 82 mm
Weight
  • On-ear headset weight (no cables): 154.5 g
  • Over-ear headset weight (no cables): 192 g
  • 3.5 mm AUX cable weight: 17.5 g
  • USB-C cable weight: 19.5 g
  • USB-A cable weight: 22 g
Compatibility
  • Works with devices that feature a 3.5mm AUX, USB-A and USB-C and most operating systems and conference platforms.
  • For users of Apple devices with a Lightning connector only, Zone Learn will require a certified 3.5mm Aux to Lightning connector adapter to work with the device.
Comfort and Fit
  • Padded PU leatherette earpads and headband comfort layer
  • Micro-articulating ear cups and adjustable slider arms
  • Even weight distribution and balanced clamping force
Listening Experience
  • 32mm driver prioritizing speech intelligibility and learning applications
  • EN 50332 Compliant
  • Over-ear variant maximizes noise isolation for focused experience
  • On-ear variant balances noise isolation with external awareness
Speaking Experience
  • Rigid, stowable boom mic with 120º rotation
  • Omni-directional pickup with gasket & noise suppressing filter
Protection and Durability
  • MIL-STD-810G drop certified up to 4 ft (1.2 m)
  • Reinforced subassemblies
Ease of Use and Management
  • 4.3’ cable length with easy-assist plug-in and cable clip for storage and swappable & upgradable ear pads and cables with hidden twist and lock design.
Sustainability and Regulatory
  • Made from a minimum of 22% recycled post-consumer materials; 100% free of PVC, VOC and paint.
Packaging and Deployment
  • Reusable education packaging designed for fast unboxing and quick scanning of products without the need to remove each item.
  • Scannable serial number and support link on product
Part Numbers
  • On-ear 3.5mm: 981-001372
  • On-ear USB-A: 981-001362
  • On-ear USB-C: 981-001367
  • Over-ear 3.5mm: 981-001389
  • Over-ear USB-A: 981-001378
  • Over-ear USB-C: 981-001383
Additional Information
Author
with
Spencer Day
210,722 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 51
All Time: 1,525
