Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Z50 Portable Speaker is a compact, battery-powered portable speaker designed for on-the-go audio playback. Its enclosure typically uses durable materials such as a rubberized housing and a metal grille to protect internal drivers from bumps and light impacts. Key features commonly include Bluetooth wireless connectivity, a 3.5 mm auxiliary input, and onboard controls for playback and volume. Documentation available in the provided sources is limited, so some specific component details are not listed on the referenced pages.
Identification
The Logitech Z50 Portable Speaker can be identified by the model number (M/N S-00138). The model label is on the underside of the speaker; auxiliary and charging ports are located on the housing side. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
- Manufacturer: Logitech (referenced support pages) - exact branding not specified in provided sources
- Connectivity: Bluetooth wireless and 3.5 mm auxiliary input (common configuration; exact Bluetooth version not specified in provided sources)
- Battery: Rechargeable Li-ion (capacity not specified in provided sources)
- Charging Port: Micro‑USB or USB‑C (exact port type not specified in provided sources)
- Drivers: Single or dual full‑range drivers behind a metal grille (exact driver model numbers not listed in provided sources)
- Audio Output: Nominal portable speaker output (RMS power not specified in provided sources)
- Frequency Response: Not specified in the provided sources
- Dimensions: Not specified in the provided sources
- Weight: Not specified in the provided sources
- Component/Part Numbers: No internal component model numbers, spare parts, or key switch manufacturers are listed in the provided sources (support pages indicate no spare parts available for similar models)
Troubleshooting
Common repair‑relevant faults include failure to power on (battery/charging fault), no audio or distorted audio (driver or connection fault), and Bluetooth pairing issues. Diagnose by checking charge status and continuity at the charging port, verifying auxiliary audio with a wired source, testing Bluetooth pairing with a known device, and using a multimeter to confirm speaker driver continuity.
For additional troubleshooting help, visit: Visit https://support.logi.com for product support, downloads, and contact options.
Additional Information
Warranty Info
Refer to Logitech warranty information on the official support site; specific warranty terms vary by region.
