Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Logitech Wireless Mouse M545 is an ergonomic, right/left-hand compatible wireless mouse designed for everyday computing and laptop use. It features a side-to-side scroll wheel, two thumb buttons, and programmable controls via Logitech software, with a nano-sized Unifying USB receiver for reliable 2.4 GHz connection. The design uses a durable plastic housing and robust mechanical components intended for long service life, and Logitech rates the mouse for extended battery life (up to 18 months) with smart sleep features. Its compact footprint and long battery life make it a common choice for mobile and office users.
Identification
The Logitech Wireless Mouse M545 includes Mouse (M/N M-R0055) and USB receiver (M/N C-U0012). Model labels are located as follows — Mouse: on the underside product label; USB Receiver: printed on the flat face or side of the receiver housing near the USB plug. Each component carries its own model (M/N) and serial (S/N) identifiers.
Specifications
  • Form Factor: Ergonomic, ambidextrous shape for right/left hand use
  • Model Number (M/N): 910-004054
  • ASIN / Item Code: ASIN B01B4SNL52
  • Connectivity: Logitech Unifying nano USB receiver (2.4 GHz)
  • Wireless Standard: 2.4 GHz RF (Logitech Unifying)
  • Power / Battery: Battery powered — 1 Lithium Polymer battery required (included); advertised battery life up to 18 months (smart sleep)
  • Physical Dimensions: 14.4 x 8.89 x 2.108 cm (as listed)
  • Weight: 95.54 g (listed)
  • Buttons: Left/right click, clickable side-to-side scroll wheel, 2 programmable thumb buttons
  • Optical Sensor / DPI: Optical sensor (resolution not specified by product page)
  • Switches: Primary button microswitch manufacturer/model not disclosed by Logitech for this product
  • Software Compatibility: Compatible with Windows and macOS via Logitech Options (serial number check on underside may affect Options compatibility); also compatible with basic SetPoint features on Windows
Troubleshooting
Common repair-relevant faults include unresponsive clicks/double-clicking (often caused by worn microswitches), scroll wheel stiction or erratic scrolling, and connectivity issues due to depleted batteries or receiver pairing. Diagnose by first swapping or checking the battery, re-plugging/re-pairing the Unifying receiver, cleaning the optical sensor and scroll wheel, and if button faults persist, open the case to inspect switches and solder joints for wear or damage.
For additional troubleshooting help, visit: See Logitech Support (support.logi.com) for product registration, software (Logitech Options), and contact details.
Additional Information
Warranty Info
Returns via retailer policies (Amazon: 30-day return window for purchases from Amazon.ca) and Logitech warranty information available on Logitech's support site; regional warranty terms vary.
Logitech M545 Wireless Mouse with Unifying Receiver Setup Guide (EN, DE, FR, IT, RU, HU, CS, PL, ET)
Logicool Wireless Mouse M545 / M546 取扱説明書
Logitech Wireless Mouse M545 Setup Guide (EN, ZH, KO)
Logitech Wireless Mouse M545 Setup Guide (EN, ZH)
Logitech Wireless Mouse M545 Setup Guide (EN, DE, FR, IT, ES, PT, NL)
Logitech Wireless Mouse M545 / M546 Setup Guide
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 56
All Time: 509
