Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Wireless Headset Mono H820e is a business-oriented single-ear wireless headset from Logitech designed for call-center and office environments. It features a noise-cancelling microphone, on-ear controls and a USB wireless transceiver for PC connectivity. The unit is built from durable ABS plastic with reinforced metal headband elements and resilient ear-cup materials to withstand daily professional use. Key features include long wireless range, rechargeable battery, and compatibility with common softphone platforms.
Identification
The Logitech WIRELESS HEADSET MONO H820E can be identified by its model number (M/N A-00049). The model label is on the underside product label. The device’s serial number (S/N) appears nearby on the same label.
Specifications
  • Manufacturer: Logitech
  • Model Number: H820e (Mono)
  • Form Factor: On-ear, single-ear (mono) wireless headset
  • Connectivity: USB wireless transceiver (proprietary Logitech wireless)
  • Microphone: Noise-cancelling boom microphone (flexible boom)
  • Battery: Rechargeable lithium-ion battery (user-replaceable in-field with disassembly)
  • Wireless Range: Up to ~30 m (100 ft) typical office range
  • Materials: Durable ABS plastic housing with reinforced metal headband inserts and resilient ear-cup foam/PU padding
  • Compatibility: Designed for PC softphones and unified communications platforms (USB audio)
  • Weight: Lightweight — approximately 30–60 g (headset only, typical mono headset range)
Troubleshooting
Common repair-relevant faults are battery failure (won't hold charge), intermittent wireless connectivity or audio dropouts, and microphone failure. Diagnose by checking/charging the battery, testing with the USB transceiver on another PC or port, re-pairing the transceiver, and inspecting the microphone boom and internal wiring for breaks or loose connectors.
For additional troubleshooting help, visit: Contact Logitech Support via https://support.logi.com for product assistance and warranty processing.
Additional Information
Warranty Info
Typically covered by a limited 1-year hardware warranty; check Logitech region-specific warranty pages for exact terms and claim procedures.
Logitech H820e Mono and Dual Wireless Headset Setup Guide (EN, FR)
Logitech Wireless Headset H820e Mono and Dual Setup Guide
Logitech Wireless Headset H820e Mono- und Dual-Version – Datenblatt
Logitech H820e Wireless Headset Data Sheet
Беспроводная гарнитура Logitech Wireless Headset H820e, одинарная и двойная версии — техническое описание
Logitech H820e Headset Sem Fio Mono e Dual — Ficha Técnica
Logitech Wireless Headset H820e Mono and Dual Data Sheet
Logitech Audio Devices – Business Headsets and Audio Solutions Overview
Logitech H820e Kabelloses Headset Datenblatt
Logitech H820e Casque sans fil DECT mono et double – Fiche technique
Logitech H820e draadloze headset (mono en dual) – datasheet
Logitech H820e Mono and Dual Wireless Headset Data Sheet
Logitech H820e Cuffia con microfono wireless Mono e Dual – scheda tecnica
Logitech H820e casque sans fil Mono et Dual – fiche technique
Logitech Wireless Headset H820e, mono- och dubbelversion – produktblad
Logitech Wireless Headset H820e Mono and Dual Setup Guide (EN, FR)
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 54
All Time: 370
