Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Ultimate Ears WONDERBOOM Play is a super-portable Bluetooth speaker designed for outdoor and on-the-go listening, offering surprisingly big sound in a compact package. It features up to 10 hours of battery life on a single charge and a new hand loop for easy carrying. The speaker is built with durable materials and an IP67 rating for dust and water protection, and the product emphasizes a lighter, more sustainable design. Active Black is listed as a model color/sku (984-001947).
Identification
The Logitech Ultimate Ears WONDERBOOM Play can be identified by the model number (M/N SR0196). The model label is under the weather door in the compartment housing the charging port. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Portable Bluetooth speaker (sealed IP67 housing)
  • Model / SKU / MPN: WONDERBOOM PLAY - Active Black, SKU/MPN: 984-001947 (productID: wonderboom-play-bluetooth)
  • Connectivity: Bluetooth wireless (version not specified by manufacturer)
  • Battery / Playtime: Rechargeable internal battery — up to 10 hours of playtime (manufacturer-stated)
  • Ingress Protection: IP67 (dustproof and waterproof)
  • Price (listed): NZD 129.95 (listed on product page)
  • Materials: Durable materials with a more sustainable design (manufacturer does not list exact material composition)
  • Label / Product Info Location: Product information (S/N, P/N, M/N) located under the weather door in the charging-port compartment
  • Charging Port: Charging port located behind weather door (exact port type not specified by manufacturer)
  • Key Switch Manufacturer: N/A (no mechanical key switches)
  • Dimensions / Weight: Not specified by manufacturer on provided product/support pages
Troubleshooting
Common repair-relevant faults include battery not charging, intermittent audio or Bluetooth dropouts, and water intrusion around the weather door. Diagnostic steps: verify the weather door is fully closed and clean, test with a known-good cable and power source, inspect charging contacts and the port compartment under the weather door, and perform a power cycle/reset; if moisture is suspected, allow the unit to dry before further testing.
For additional troubleshooting help, visit: See Ultimate Ears / Logitech support pages for contact options and product registration (support contact info and product registration links available on the support site).
Additional Information
Warranty Info
Warranty details are provided via Logitech/Ultimate Ears support — consult the support page or your region's warranty terms for coverage and claim instructions.
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 566
