Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The USB Headset Mono H650e is a single-ear USB headset from Logitech designed for professional unified communications and call-center use. It features a noise-canceling boom microphone, on-cable or on-ear controls for call answer/end and volume, and plug-and-play USB connectivity for easy deployment. The design uses durable materials including a metal-reinforced headband and reinforced cable strain relief to withstand daily use. Key features include a flexible boom mic for clear voice pickup, single-ear monitoring for situational awareness, and compatibility with major operating systems.
Identification
The Logitech USB Headset Mono H650e can be identified by its model number (M/N A-00050). The model label is on the underside product label. The device’s serial number (S/N) appears nearby on the same label.
Specifications
- Manufacturer: Logitech
- Model: USB Headset Mono H650e
- Part Number(s): H650e (SKU and regional part numbers vary; check product label)
- Connectivity: Wired USB-A (plug-and-play; USB 2.0 compatible)
- Earpiece: Mono (single-ear) on-ear design with leatherette cushion
- Microphone: Noise-canceling unidirectional boom microphone (flexible boom)
- Controls: Inline or on-ear call answer/end, mute, and volume controls (location varies by SKU)
- Construction: Durable materials: metal-reinforced headband, reinforced cable strain relief and durable plastics
- Compatibility: Designed for unified communications; compatible with Windows and macOS via USB plug-and-play
- Cable: Fixed USB-A cable (length varies by SKU; check product label)
Troubleshooting
Common repair-relevant faults include no audio/output, microphone not detected, and cable or connector damage. Diagnose by testing the headset on a different USB port or computer, inspecting the cable and USB plug for visible damage, verifying mute/volume controls, and checking OS audio device settings. For intermittent audio, use a multimeter to check cable continuity and visually inspect solder joints at connector points.
For additional troubleshooting help, visit: Visit https://support.logi.com for product support, contact options, and guides.
Additional Information
Warranty Info
Refer to Logitech's warranty page for region-specific limited hardware warranty details and instructions to file a claim.
Logitech H650e Mono/Stereo Setup Guide (EN, DE, FR, IT, ES, PT, NL, SV, DA, NO, EL, RU, HU, CS, PL)
Logitech USB Headset H650e Mono and Stereo Setup Guide (EN, ZH)
Logitech USB Headset H650e Data Sheet
羅技 USB 耳機麥克風 H650e 單聲道與立體聲產品資料表
Logitech USB Headset H650e Stereo Product Information Sheet
Logitech USB Headset H650e Mono und Stereo – Datenblatt
Logitech USB Headset H650e Stereo Data Sheet
Logitech H-Series Business Headsets – Vergleichsmatrix
Logitech USB Headset H650e folleto
Logitech H650e Headset Datasheet
Logitech USB Headset H650e Datasheet
Logitech USB Headset H650e – Fiche produit, versions mono et stéréo
Logitech H650e USB Headset Data Sheet
Logitech USB Headset H650e estéreo — ficha de producto
Logitech USB Headset H650e Mono and Stereo Setup Guide (EN, FR)
