Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Logitech Signature PLUS M750 L is a wireless Signature-series mouse positioned for everyday productivity with simple, durable construction. It uses a sturdy polymer housing and durable switches designed for long-term use and repeated clicking. Key features called out in Logitech support include wireless connectivity compatible with Logi Options+ and guidance about Logi Bolt/connection utilities. Detailed hardware specs and spare parts listings are not provided on the official support page.
Identification
The Logitech Signature PLUS M750 L can be identified by the model number (M/N CU0021). The model label is on the underside of the mouse; any included Logi Bolt receiver model number is printed on the receiver housing. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Compact wireless mouse (Signature family)
  • Connectivity: Bluetooth Low Energy and Logi Bolt USB receiver compatibility (support page references Logi Options+ for software)
  • Sensor: Optical sensor (exact model not specified on Logitech support page)
  • DPI / Sensitivity: Not specified on the official Logitech support article
  • Primary click switches: Manufacturer/model not listed on Logitech support page (not published)
  • Battery: Not specified on the official Logitech support article (spare parts and battery details not listed)
  • Onboard memory / Buttons: Multi-button layout with programmable functions via Logi Options+; onboard memory information not provided
  • Dimensions & Weight: Not published on the Logitech support article
  • Included components / model numbers: No spare parts or separate model numbers listed on Logitech support page (receiver/model numbers not published)
  • Software / Firmware: Supported by Logi Options+; legacy firmware update tools and older Logitech utilities are deprecated per the support page
Troubleshooting
Common repair-relevant faults are unresponsive clicks, intermittent wireless connectivity, and power/battery issues. Diagnose by checking battery or power source, re-pairing via Bluetooth or Logi Bolt, testing with another USB port or receiver, and inspecting the underside/scroll area for debris or mechanical obstruction.
For additional troubleshooting help, visit: Visit support.logi.com for product support and to access Logi Options+ software guidance; the product support page indicates limited downloadable resources and lists contact options.
Additional Information
Warranty Info
See Logitech warranty page; region-dependent limited hardware warranty (duration varies by country). The support page links to Logitech warranty information.
Logitech Signature Slim Combo MK955 for Business Copilot Edition Datasheet
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 71
All Time: 481
