Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Snowball iCE Ubisoft Bundle is a rebranded variant of Logitech’s Snowball iCE USB condenser microphone designed for desktop streaming, podcasting, and voice chat. It features a cardioid condenser capsule and plug-and-play USB connectivity for Windows and macOS. The microphone uses durable materials including a metal grille and a weighted metal base/stand for stability. Key features include a compact profile, single-pattern cardioid pickup optimized for close-up vocals, and simple USB power with no external interface required.
Identification
The Logitech SNOWBALL ICE UBISOFT BNDL can be identified by the model number (M/N A00145). The model label is on the underside of the microphone base and bundle-specific packaging/stickers indicate the Ubisoft promotion. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Manufacturer: Logitech
  • Model: Snowball iCE (Ubisoft bundle variant)
  • Form Factor: Desktop USB condenser microphone with integrated metal stand/base
  • Polar Pattern: Cardioid (single pattern)
  • Capsule Type: Condenser capsule (fixed, internal)
  • Audio Resolution: 16‑bit, 44.1/48 kHz (USB PCM, plug-and-play)
  • Connectivity: USB 2.0 Type-A (integrated cable)
  • Power: Bus-powered via USB port
  • OS Compatibility: Windows and macOS (plug-and-play; drivers not typically required)
  • Dimensions & Weight: Compact desktop form; microphone with metal base for weighted stability (manufacturer lists as small desktop mic)
  • Included Accessories: Integrated USB cable, adjustable metal base/stand; Ubisoft bundle may include promotional materials (no separate accessory SKUs listed on Logitech support)
Troubleshooting
Common faults are detection/power failures (usually caused by a faulty USB cable/port or host recognition issues) and intermittent audio/dropouts. Diagnose by testing the mic on another USB port or computer, inspecting the USB cable and connector for damage, and checking the OS sound/device manager for recognition and default-input settings.
For additional troubleshooting help, visit: Contact Logitech support via https://support.logi.com for troubleshooting, warranty claims, and product information.
Additional Information
Warranty Info
Refer to Logitech’s regional warranty page (see support.logi.com/warranty) for terms; warranty length varies by region.
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 197
