Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The RS Wheel Hub is a modular steering wheel adapter designed to let drivers personalize Logitech G racing setups by attaching Racing Series or MOMO × Logitech G steering wheels to Logitech G Direct Drive bases. It is built from durable metal components and reinforced plastics for long-term use and stable wheel mounting. Key features include a quick‑release attachment, width‑adjustable or fully removable gear shifters, and LIGHTSYNC RGB rev lights for visual RPM feedback. The hub is offered in platform-specific SKUs for PC and Xbox/PC compatibility.
Identification
The Logitech RS Wheel Hub for Xbox/PC can be identified by the model number (M/N WU0017). The model label is on the hub housing and packaging. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Platform Compatibility: PC; Xbox/PC variant (select SKU for Xbox compatibility)
  • Model Numbers / SKUs: PC: 941-000234; Xbox/PC: 941-000233 (MPN matches SKU)
  • Attachment: Quick‑release mount compatible with Logitech G Racing Series and MOMO × Logitech G steering wheels and Logitech G Direct Drive bases
  • Materials: Durable metal mounting components with reinforced engineering plastics for exterior housing
  • Gear Shifters: Width‑adjustable or fully removable gear shifters for left/right placement and ergonomic customization
  • Lighting: LIGHTSYNC RGB rev lights (visual RPM/shift indicators)
  • Software / Configuration: Supported by Logitech G online configurator for component selection; no separate firmware downloads listed on Logitech support for this product
  • Physical Interface: Proprietary quick‑release mechanical interface to Logitech G bases (no standard USB connection on hub itself)
  • Color / Finish: Black
  • Packaging / Included Items: RS Wheel Hub unit; quick‑release interface; mounting hardware and documentation (varies by region)
Troubleshooting
Common faults include the hub not being recognized by the wheel base, RGB rev lights not illuminating, or mechanical play/wear in the quick‑release and shifter mounts. Diagnose by confirming correct platform SKU and base compatibility, reseating the quick‑release coupling and any cables, inspecting for damaged or loose mounting hardware, and testing with a known‑good Logitech G Direct Drive base.
For additional troubleshooting help, visit: https://support.logi.com/hc/en-us/articl...
Additional Information
Warranty Info
Refer to Logitech warranty page for regional limited hardware warranty terms; warranty period varies by region.
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 40
All Time: 549
