Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Parts
Logitech Parts
Background
The PRO X Superlight 2 SE is a lightweight wireless gaming mouse designed for competitive and general gaming use. It uses Logitech’s HERO 2 optical sensor for high-resolution tracking and connects through LIGHTSPEED wireless at a standard 1,000 Hz polling rate. It weighs roughly 60 grams and has PTFE feet to support low-friction movement across common mousepad surfaces. Charging is handled via USB-C, and the internal battery is rated for extended use between charges.
The mouse includes onboard memory for profile storage and is configured through Logitech G HUB for DPI adjustments, button assignments, and firmware updates. The supplied receiver supports a 1000 Hz report rate. An optional Pro Lightspeed receiver, sold separately, enables report rates up to 8000 Hz.
Identification
The Logitech Pro X Superlight 2 SE can be identified by the model number (M/N MR0097). The model label can be found inside the battery compartment.
Additional Information
Author
with
Kara Piepenbrink
8,347 Reputation
21 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 133
All Time: 823
