Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The PRO RACING WHEEL is a high-performance racing wheel designed for simulation and esports use. It is built with durable materials including metal components and reinforced plastics to withstand sustained use and strong force-feedback forces. Key features include force feedback, compatible pedal set, and quick-release wheel attachment for accessory interchangeability. Official support documentation lists no downloadable firmware or spare parts for this product.
Identification
The Logitech PRO RACING WHEEL can be identified by the model number (M/N WU0008). The model label is on the underside of the wheel base and on the underside of the pedal assembly. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Sim racing wheel base with detachable wheel rim and separate pedal unit
  • Compatibility: PC and consoles (specific supported platforms not listed on support page)
  • Connectivity: Wired USB (exact connector type not specified on support page)
  • Power: External power supply required (details not listed on support page)
  • Force Feedback: Force feedback supported (motor type and torque not listed on support page)
  • Pedals Included: Three-pedal set (accelerator, brake, clutch) — model numbers not provided on support page
  • Materials: Durable metal components and reinforced plastics (support page emphasizes durability but gives no detailed material spec)
  • Buttons / Switches: Multi-function buttons and paddle shifters present — exact key switch manufacturer/model not listed on support page
  • Firmware / Software: No downloads available on Logitech support page; Logi Options+ recommended for supported Logitech devices per support content
  • Spare Parts / Model Numbers: Support page states there are no spare parts or documents available and no model numbers listed for components
Troubleshooting
Common repair-relevant faults include loss of force feedback, USB connectivity failures, and pedal calibration issues; first-line diagnostics are to check power and USB connections, try alternate USB ports/cables, and confirm the device appears in the OS. If force feedback or buttons fail, verify firmware/software status via Logi Options+ and test with another PC to isolate hardware versus software faults. Support page notes no spare parts or downloads are available, so contact Logitech support if hardware replacement is needed.
For additional troubleshooting help, visit: Visit Logitech Support for contact options and warranty assistance: https://support.logi.com/hc/en-us/articl...
Additional Information
Warranty Info
Refer to Logitech warranty information; the support page links to general warranty resources but provides no product-specific warranty period or terms
Logitech Pro Racing Wheel for PlayStation 5, PlayStation 4 and PC Setup Guide (EN, FR)
Logitech PRO RACING WHEEL for PC Setup Guide (EN, ZH, KO)
PRO RACING WHEEL for Xbox Series XIS, Xbox One and PC Setup Guide (EN, FR)
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 52
All Time: 481
