Ask a Question
There are no questions. Be the first to ask a question!
Background
The MIXAMP PRO TR GEN4 XB1 is a console-focused external audio interface and mixer designed to provide pro-level game/chat audio control for Xbox platforms. It offers USB and optical (Toslink) connectivity, on-board game/chat balance, EQ presets, and virtual surround processing for compatible headsets. The unit is built from durable materials — a reinforced ABS plastic housing with an aluminum top plate — to withstand regular desktop use and cable handling. Key features include low-latency digital audio conversion, hardware EQ/voice monitoring controls, and pass-through connectivity for consoles and PCs.
Identification
The Logitech MIXAMP PRO TR GEN4 XB1 can be identified by the model number (M/N A00084). The model label is on the top and a regulatory label on the underside containing serial/model information. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: External desktop USB/audio interface (mixing amp)
  • Compatibility: Xbox One / Xbox Series X|S (Xbox mode), compatible with PC via USB
  • Connectivity: USB (data & power), Optical (Toslink) input/output, 3.5 mm headset/amp port
  • Audio Processing: On-board EQ presets and virtual surround processing (Dolby-style virtualization for stereo headsets)
  • Digital-to-Analog Converter (DAC): High-resolution DAC (manufacturer model not publicly documented)
  • Controls: Top-mounted volume/EQ dial, game/chat balance wheel, mic sidetone and mute controls
  • Power: USB bus-powered (5 V USB, typical current draw depends on usage)
  • Materials: Reinforced ABS plastic housing with aluminum top plate for durability
  • Firmware / Software: Firmware updatable via vendor software; note the legacy firmware update tool has been deprecated by Logitech (see support)
  • Ports / Connectors: USB data/power port, Toslink optical in/out, 3.5 mm TRS headset jack, rear-facing console/PC pass-through
Troubleshooting
Common repair-relevant faults include no audio (often caused by faulty optical or USB cables), no power (defective USB cable or internal power connection), and intermittent audio/dropouts (loose connectors or failing internal solder joints). Diagnose by swapping known-good USB and optical cables, testing the unit on another host, checking firmware status, and opening the unit to inspect connectors and solder joints if cables are verified good.
For additional troubleshooting help, visit: Visit Logitech Support (support.logi.com) or the product support article for MixAmp devices for downloads and assistance.
Additional Information
Warranty Info
Refer to Logitech warranty terms available through Logitech Support; warranty length varies by region and purchase channel.
Tim Asp
42,335 Reputation
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 28
All Time: 190
