Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Litra Beam LX is a compact streaming and content-creation light from Logitech designed for on-camera or desktop use. It offers tunable color temperature and adjustable brightness in a small footprint, and is built with durable materials including an anodized aluminum housing and reinforced polycarbonate diffuser. Key features include USB-C power, a magnetic detachable mount and adjustable beam shaping for consistent, high-CRI output. The unit targets streamers and creators who need reliable, portable lighting with durable construction and simple mounting options.
Identification
The Logitech LITRA BEAM LX can be identified by the model number (M/N VR0036). The model label is on the rear housing and the model label on the underside of the unit. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Compact on-camera / desktop LED light
  • Model Number(s): Litra Beam LX (model label on underside) — accessory mount included (no separate model number listed on support page)
  • Light Source: Tunable high-CRI white LEDs (manufacturer not specified on support page)
  • Color Temperature: Adjustable (approx. 2700 K to 6500 K; exact range per manufacturer documentation)
  • Color Rendering Index (CRI): High CRI (manufacturer lists high-CRI performance; exact number not specified on support page)
  • Power & Connectivity: USB-C powered (standard 5 V USB power; specific input current/PD profile not documented on support page)
  • Housing Materials: Anodized aluminum housing with reinforced polycarbonate diffuser and magnetic mount components
  • Mounting: Detachable magnetic mount / puck; desk and camera mounting compatibility
  • Controls: On-device brightness and color controls plus software integration via Logitech apps (see support) — firmware updates handled via Logitech software when available
  • Dimensions & Weight: Compact footprint suitable for desktop use; exact dimensions and weight not specified on support page
Troubleshooting
Common repair-relevant faults include no-power (unit fails to light), intermittent flicker, and physical mount failure. Diagnose by testing alternate USB-C cables and power sources, inspect the USB-C port and cable for damage, verify firmware/software integration if applicable, and check magnetic mount and mounting points for mechanical wear.
For additional troubleshooting help, visit: Visit https://support.logi.com and search for Litra Beam LX for drivers, downloads, and support articles.
Additional Information
Warranty Info
Warranty varies by region; check Logitech's warranty portal (support.logi.com) for terms and claim procedures.
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 46
All Time: 375
