Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The G Pro wired headset was launched as part of Logitech's G series line. It's the European release of the G Pro X Wired Headset. This gaming headset comes equipped with surround sound and Pro-G 50 mm drivers. The G Pro wired headset is made of steel and aluminum and has memory foam ear pads.
Identification
The G Pro wired headset has oval-shaped ear cups with the Logitech logo etched in metal on the outside. The top of the headband has "Pro" written in the leatherette. This headset only has two jacks on the bottom of the left cup for the cable and microphone. It looks nearly identical to the G Pro X Wired Headset. You can find the part number (P/N) and model number (M/N) by removing the left ear pad and looking on the ear cup. The G Pro headset has model number A00101.
Technical Specifications
Dimensions
  • Length: 5.43 in (138 mm)
  • Width: 3.70 in (94 mm)
  • Height: 7.68 in (195 mm)
  • Weight: 11.29 oz (320 g)
  • PC cable length: 6.6 ft (2 m)
  • PC splitter: 4.72 in (120 mm)
Headphone
  • Driver: Hybrid mesh PRO-G 1.97 in (50 mm)
  • Magnet: Neodymium
  • Frequency response: 20 Hz - 20 kHz
  • Impedance: 32 Ohms
  • Sensitivity: 91.7 dB SPL @ 1 mW & 1 cm
Materials
  • Fork: Aluminum
  • Headband: Steel
  • Ear and head pads: Memory foam leatherette
Microphone
  • Pickup pattern: Cardioid (unidirectional)
  • Type: Electret condenser
  • Size: 0.24 in (6 mm)
  • Frequency response: 100 Hz - 10 KHz
Compatibility
  • PC with USB port
  • Windows 7 or later
Additional Information
Spencer Day
210,749 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 25
Past 30 Days: 107
All Time: 2,219
