Background
The Logitech G560 LIGHTSYNC Gaming Speakers are a 2.1 desktop gaming speaker system designed for immersive PC audio with integrated RGB lighting. The system combines two satellite speakers and a powered down-firing subwoofer, and uses durable plastic and metal mesh grilles in the satellites for everyday bump and scratch resistance. Key features include LIGHTSYNC RGB lighting across multiple zones, USB connectivity for PC audio+lighting control, and compatibility with Logitech G HUB and DTS:X Ultra for spatial audio tuning. An external AC adapter provides power and helps keep heat-generating components isolated from the speaker enclosures.
Identification
The Logitech G560 LIGHTSYNC Gaming Speakers can be identified by the model number (M/N SR0198). The model label is on the product and packaging. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • System: 2.1 channel (two satellites + powered down-firing subwoofer)
  • Lighting: LIGHTSYNC RGB with 16.8 million colors and multiple lighting zones; controlled via Logitech G HUB
  • Connectivity: USB (PC audio + lighting control) and 3.5 mm analog aux input; USB required for full RGB and software features
  • Software: Logitech G HUB (software-controlled lighting effects, equalizer, DTS:X Ultra support on PC)
  • Power: External AC adapter (ships with unit); total power up to 240 W peak (manufacturer-stated), speaker output managed by internal amplifier
  • Drivers: Satellites: full-range drivers in each satellite; Subwoofer: single down-firing subwoofer (≈6 inch driver) — driver model numbers not listed on support page
  • Frequency Response: Approximately 40 Hz – 20 kHz (typical for 2.1 desktop gaming systems)
  • Inputs/Controls: Volume and headphone passthrough on satellite; rear-panel input and power connections on subwoofer for cable routing
  • Compatibility: Windows PC (full functionality via USB + G HUB); analog devices via 3.5 mm input (lighting & software features limited)
  • Model Numbers / Regulatory: No separate component model numbers or spare-part IDs listed on the referenced support page; full product ID appears as G560 LIGHTSYNC on Logitech materials
Troubleshooting
Common faults include no power, no audio, or lighting not functioning. Diagnose by verifying AC adapter and power outlet, testing alternate audio inputs (USB vs 3.5 mm), reinstalling/updating Logitech G HUB, and inspecting speaker cables and internal fuse or solder joints for continuity.
For additional troubleshooting help, visit: Visit https://support.logi.com for drivers, G HUB downloads, and official troubleshooting articles.
Additional Information
Warranty Info
Warranty varies by region; consult Logitech support — typical limited hardware warranty (often 1 year) applies.
Tim Asp
42,335 Reputation
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 63
All Time: 471
