Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The G513 CARBON is a full-size mechanical gaming keyboard designed for performance and durability, featuring per-key RGB lighting and dedicated media controls. Its top case is machined from aircraft-grade 5052 aluminum-magnesium alloy for a rigid, premium feel and long-term durability. The keyboard ships with Logitech Romer‑G mechanical switches (Tactile or Linear variants), a detachable palm rest, and a USB 2.0 passthrough for added connectivity. Additional features include onboard macro support, tilt legs, and compatibility with Logitech gaming software for customization.
Identification
The Logitech G513 CARBON can be identified by the model number (M/N Y-U0034). The model label is on the underside of the keyboard. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Full-size mechanical gaming keyboard with numpad
  • Switch Manufacturer / Model: Romer‑G (Logitech) — available in Romer‑G Tactile and Romer‑G Linear variants
  • Switch Specs: Actuation distance 1.5 mm; Actuation force 45 gf; Total travel 3.0 mm
  • Top Case Material: Aircraft‑grade 5052 aluminum‑magnesium alloy
  • Backlighting: Per‑key RGB, selectable colors and lighting effects (FN shortcuts for onboard effects)
  • Connectivity: Wired USB Type‑A (USB 2.0, full speed); 1x USB 2.0 passthrough port
  • Cable Length: 1.8 m (6 ft)
  • Model Number (M/N): Y‑U0034 (printed on underside)
  • Dimensions (Keyboard): Height 132 mm; Width 445 mm; Depth 34 mm; Weight 1105 g (without cable)
  • Palm Rest: Dimensions 89 mm x 445 mm x 21 mm; Weight 406 g; detachable
  • Software / OS Support: Logitech Gaming Software (at release) and ARX Control; Windows 7, 8, 8.1, 10 supported
  • USB Vendor/Product ID: VID_046D (Logitech) & PID_C33C
Troubleshooting
Common repair‑relevant faults include non‑responsive or intermittent keys (often due to failed switches or solder joints), backlight or LED failures, and USB cable/passthrough connectivity problems. Diagnose by testing on a known‑good USB port/cable, verifying settings in Logitech software, removing keycaps to inspect/test individual switches, and checking the cable and internal solder joints with continuity testing before replacing parts.
For additional troubleshooting help, visit: Visit https://support.logi.com for drivers, downloads, and product support specific to G513.
Additional Information
Warranty Info
Limited hardware warranty varies by region (commonly 1–2 years); check Logitech warranty pages for exact terms.
G513 RGB Mechanical Gaming Keyboard Instructions
G513 RGB Mechanical Gaming Keyboard Features Guide
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 97
All Time: 888
