Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Logitech G512 Carbon is a full‑size mechanical gaming keyboard built for durability and performance. It features Logitech’s Romer‑G mechanical switches (available in tactile or linear variants), per‑key RGB lighting, and a USB 2.0 passthrough for peripherals. The top case is made from aircraft‑grade 5052 aluminum‑magnesium alloy, giving the keyboard a rigid, premium feel and improved longevity. Other notable features include onboard media controls via Fn keys, a braided 1.8 m USB Type‑A cable, and software customization support.
Identification
The Logitech G512 CARBON can be identified by its model number (M/N Y-U0034). The model label is on underside. The device’s serial number (S/N) appears nearby on the same label.
Specifications
  • Form Factor: Full‑size (with numeric keypad)
  • Connection Type: USB Type‑A (corded) with 1 USB 2.0 passthrough port
  • USB VID/PID: VID_046D & PID_C33C
  • USB Protocol/Speed: USB 2.0 (Full Speed)
  • Cable Length: 1.8 m (6 ft) braided USB cable
  • Switches (manufacturer/model): Logitech Romer‑G (Romer‑G Tactile and Romer‑G Linear mechanical switches)
  • Actuation Distance: 1.5 mm
  • Actuation Force: 45 gf
  • Total Travel: 3.0 mm
  • Backlighting: Per‑key RGB, selectable colors and lighting effects
  • Top Case Material: Aircraft‑grade 5052 aluminum‑magnesium alloy
  • Dimensions & Weight: 132 mm H × 445 mm W × 34 mm D; 1020 g (without cable)
Troubleshooting
Common repair‑relevant faults include non‑responsive or sticking keys (worn/damaged switches), backlight or LED failure, and intermittent USB/passthrough connectivity often caused by cable damage or loose solder joints. Diagnose by removing keycaps to test individual switches, testing on a known‑good USB port/cable, verifying passthrough functionality, and opening the case to inspect cable connectors and solder joints; switch replacement requires desoldering and resoldering.
For additional troubleshooting help, visit: Visit https://support.logi.com for drivers, downloads, and contact options.
Additional Information
Warranty Info
See Logitech warranty information on the official support site for regional limited warranty terms and claim procedures.
G512 RGB Mechanical Gaming Keyboard Features Guide
G512 RGB Mechanical Gaming Keyboard Instructions
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 11
Past 7 Days: 50
Past 30 Days: 222
All Time: 1,403
