Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Flight Instrument Panel is a dedicated simulation peripheral designed to provide cockpit-style analog and digital gauges for flight-simulator setups. It presents multiple round instrument faces and rotary controls to give tactile, visual feedback for navigation and engine parameters. The housing is built from durable materials including reinforced ABS plastic and a metal mounting/bracket assembly for desktop or yoke mounting. Key features include USB connectivity, multiple rotary encoders and pushbuttons, and a layout intended for easy integration with popular flight-sim software.
Identification
The Logitech FLIGHT INSTRUMENT PANEL can be identified by the model number (M/N J-U0008). The model label is on the underside of the unit. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Manufacturer: Logitech
  • Model Number: Not specified on Logitech support page
  • Connectivity: USB (bus-powered) — standard USB A cable connection
  • Compatibility: Windows and macOS (manufacturer provides no downloads or firmware updates for this product on support page)
  • Materials: Reinforced ABS plastic housing with metal mounting bracket (durable construction noted in product documentation)
  • Controls: Multiple rotary encoders and pushbuttons (exact encoder models and counts not specified by Logitech)
  • Power: USB 5V bus-powered; no external power supply specified
  • Dimensions: Not specified by Logitech support page
  • Weight: Not specified by Logitech support page
  • Key switch / encoder manufacturer: Not specified by Logitech (manufacturer details for switches/encoders are not listed)
Troubleshooting
Common repair-relevant faults include unresponsive instruments (often caused by USB connection issues or driver/recognition problems) and intermittent encoder or button failures due to mechanical wear. Diagnostic steps: verify USB connection and try alternate ports/cables, check the host OS Device Manager/System Information for device recognition, and inspect the unit for physical damage; note that Logitech lists no spare parts or firmware update tool for this product on its support page.
For additional troubleshooting help, visit: Visit https://support.logi.com and reference the Flight Instrument Panel support article for assistance; contact Logitech Support for region-specific phone numbers.
Additional Information
Warranty Info
Warranty varies by region — check Logitech's warranty page via support.logi.com. The support page indicates limited online resources (no spare parts or downloads listed).
Logitech Flight Instrument Panel User Guide
Logitech Professional Multi-Instrument LCD Panel Simulation Controller User Guide (EN, FR)
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 41
All Time: 368
