1 Answer 1 Score |
Why does the 1st and 2nd gear shifts to wrong one |
2 Answers 0 Score |
make this into usb |
Documents
Background
The Driving Force Shifter is a dedicated 6-speed gated shifter accessory designed to add realistic manual shifting to compatible Logitech wheel bases. It uses durable materials — a metal shift gate and a leather-wrapped shift knob — combined with a robust ABS plastic housing to withstand repeated use. Key features include an H-pattern 6-speed layout with push-down reverse and a clamp/bolt mounting system for table or floor installation. Official Logitech support documentation notes there are no downloadable spare parts or software packages specifically for the shifter.
Identification
The Logitech DRIVING FORCE SHIFTER can be identified by the model number (M/N W-U0003). The model label is on the underside of the unit. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
- Form Factor: 6-speed H-pattern gated shifter (floor or desk mount)
- Shift Pattern: 6-speed H-pattern with push-down reverse
- Compatibility: Designed for Logitech Driving Force wheel bases (e.g., G29, G920); compatibility depends on wheel/console
- Construction: Metal shift gate, leather-wrapped (or leather-like) shift knob, ABS plastic housing
- Mounting: Clamp for desk mounting and bolt-through holes for floor mounting; includes mounting hardware
- Connection: Wired connection to compatible Logitech wheel base via proprietary cable/port (powers and communicates through wheel)
- Model Number: Not listed on Logitech support article; model/serial label located on underside of the unit
- Key Switch Manufacturer: Not applicable — mechanical gear mechanism; no electronic key switches reported
- Spare Parts Availability: Logitech support page states there are no spare parts available for this product
- Power: Powered through wheel base connection; no separate battery or mains input
Troubleshooting
Common repair-relevant faults are mechanical stiffness or worn shift gate, loose or damaged mounting hardware, and loss of communication with the wheel ( connector/cable faults). Diagnose by inspecting mounting bolts and gate for play or debris, checking the shifter-to-wheel cable and connector for corrosion or damage, and verifying operation with a known-compatible wheel and up-to-date Logitech software (Logi Options+ where applicable).
For additional troubleshooting help, visit: Refer to Logitech Support (https://support.logi.com/) for general assistance; the product support article for Driving Force Shifter notes no downloads or spare parts for this product.
Additional Information
Warranty Info
Warranty varies by region; consult Logitech's warranty page linked from their support site for region-specific terms. The support article advises checking Logitech warranty information.
