Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Logitech C920 HD Pro Webcam is a Full HD webcam designed for video conferencing and content creation, offering 1080p video at 30 fps and dual stereo microphones. It uses a full HD glass lens and features HD auto light correction and a 78° field of view for clear, detailed images. The housing emphasizes durable construction and sustainability, incorporating recycled plastic in its materials. Key features include crisp Full HD capture, stereo audio, and a stable mounting clip for monitors or tripods.
Identification
The Logitech C920 HD Pro Webcam can be identified by the model number (M/N VU0062). The model label is on the unit; the Logitech branding and product name are visible on the front housing and the regulatory/model label is typically located on the underside. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Brand: Logitech
  • Model Number / SKU / MPN: 960-001055
  • Video Resolution: Full HD 1080p at 30 fps
  • Lens: Full HD glass lens
  • Field of View: 78°
  • Auto Exposure / Light Correction: HD auto light correction
  • Microphones: Dual omnidirectional microphones for stereo audio
  • Materials: Durable housing built with recycled plastic (sustainability-focused)
  • Carbon footprint: Approx. 5.66 kg CO2e (product lifecycle estimate listed on product page)
  • Category: Webcam (consumer/professional video accessory)
  • Item / Product ID: c920-pro-hd-webcam
Troubleshooting
Common repair-relevant faults include no video output (often due to cable or port failure), poor image quality from dirt or damaged lens, and audio dropouts from mic or wiring faults; begin diagnostics by testing the webcam on a different USB port or computer, inspecting the cable and connector for visible damage, cleaning the lens, and checking software/driver settings. If the cable or internal wiring is suspected, continuity checks and visual inspection after disassembly are recommended. Replace the integrated cable or microphone module if diagnostics confirm physical failure.
For additional troubleshooting help, visit: Visit https://support.logi.com for drivers, downloads, and product support specific to the C920 HD Pro Webcam.
Additional Information
Warranty Info
Limited hardware warranty varies by region; check Logitech support or your local retailer for exact warranty term and coverage.
Logitech HD Pro Webcam C920 Setup Guide
Logitech HD Pro Webcam C920 Setup Guide (EN, ZH)
Logicool C920 PRO HDウェブカメラ セットアップガイド
Logitech C920 Pro HD Webcam Complete Setup Guide
Logitech C920 Pro HD Webcam Setup Guide
Applied Concepts CopTrax In-Car Police Video System — Logitech C920 Case Study
Logitech HD Pro Webcam C920 CopTrax Case Study
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 52
All Time: 394
