Ask a Question
There are no questions. Be the first to ask a question!
Background
The Astro A10 STAR KILLER BASE is a wired gaming headset based on the Astro A10 Gen‑2 platform, designed for cross‑platform play and everyday durability. It uses custom‑tuned 32 mm dynamic drivers and a flip‑to‑mute boom microphone to deliver clear game and chat audio. The design emphasizes rugged durability with an ultra‑durable headband and reinforced housing materials for long service life, plus inline volume controls for quick adjustments. Wired 3.5 mm connectivity ensures broad compatibility with consoles and PCs.
Identification
The Logitech Astro A10 STAR KILLER BASE can be identified by its model number (M/N A00160). The model label is inside the headband or on an earcup label. The device’s serial number (S/N) appears nearby on the same label.
Specifications
  • Form Factor: Wired over‑ear closed‑back gaming headset
  • Drivers: Custom‑tuned 32 mm dynamic drivers (Astro A10 Gen‑2)
  • Microphone: Flip‑to‑mute boom microphone (integrated, designed for voice chat)
  • Connectivity: 3.5 mm wired (integrated cable) — broad console/PC compatibility
  • Inline Controls: Inline volume control and mute on cable
  • Materials: Reinforced headband and robust earcup housing (ultra‑durable construction per manufacturer)
  • Model Numbers / SKUs: ProductID: a10-gen-2; MPN/SKUs: 939-002069, 939-002050, 939-002076, 939-002062, 939-002055, 939-002045, 939-002083
  • Weight: Not specified by manufacturer (lightweight, designed for long sessions)
  • Frequency Response / Impedance: Not specified by manufacturer
  • Included Items: A10 headset; no MixAmp included with base model; packaging and documentation vary by SKU
Troubleshooting
Common repair‑relevant faults include cable damage or intermittent audio, broken boom mic or mute switch, and worn ear cushions. Diagnose by testing continuity with a multimeter, trying the headset on a known‑good device to isolate host vs headset faults, visually inspecting the cable and inline control, and accessing the earcup cavity to check driver connection.
For additional troubleshooting help, visit: Support and replacement guidance available at https://support.logi.com (search A10 or product ID a10-gen-2).
Additional Information
Warranty Info
Manufacturer warranty varies by region; check Logitech warranty portal — typically a limited hardware warranty (period varies by country).
Tim Asp
42,386 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 47
All Time: 528
