Up to 20% off select tools
Documents
Background Information
The Lofree Touch is a mechanical mouse that features a menimalist design based off of the classic 1984 Macintosh, while also featuring modern specs including five factory-set DPI levels up to 4000 DPI, and a dot matrix OLED display. Users also have the option to swap out the buttons and case components to costomize the look of the mouse.
Technical Specifications
General Information
  • Manufacturer: Lofree
  • Hand Design: Asymmetrical design for right-hand use only
  • Color Options:
    • Tofu
    • Block
  • Case Options:
    • Crazy Banana
    • Dear Kitty
    • Alice Wonderland
  • Materials: Polybutylene terephthalate (PBT)
  • Bluetooth Name: Touch@Lofree
Connectivity
  • Connection Types:
    • Bluetooth
    • 2.4G
    • Wired USB-C Cable
  • 2.5G Transmitted Power: <10mW
  • Max Simultaneous Connection: 4
Buttons
  • Total Buttons: 9
    • 7 x User Buttons
      • Left/Right Click
      • Middle Mouse Button (Middle Button, forward/backwards)
      • Forward/Backwards Side Buttons
      • DPI Key
    • 1 x On/Off Switch
    • 1 x DPI Key
Tracking
  • Sensor: PAW3805
  • DPI Levels: 6 Levels
    • 800
    • 1200
    • 1600
    • 2400
    • 3600
    • 4000
Sensor Technology
  • Sensor: PAW3805
  • Sensor Type: Optical
  • Polling Rate: 500 Hz
Display Information
  • Display Type: OLED
Power Source
  • Battery Type: Lithium Ion
  • Charging Method: USB-C
  • Battery Life: Up to 4 Weeks
  • Battery Capacity: 650 mAh
  • Voltage: 3.7 V
Physical Dimensions
  • Dimensions:
    • Length: 4.25 in (108 mm)
    • Width: 2.7 in (68.5 mm)
    • Height: 1.67 in (42.5 mm)
  • Weight: 3.72 oz (105.5 g)
OS Compatibility
What's in the Box
  • 1 x Lofree Touch Mouse
  • 1 x USB-C to USB-A Charging Cable
  • 1 x User Manual
Addional Information
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 116
All Time: 1,330
