No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
AC-225
Important Information
WCTA is no longer supplying 9S repair/replacement parts. Please contact Lincoln directly at 888-935-3876 and select option 1 for repair parts. They can work to insure you have the correct repair part as well as offer a Distributor in your area so you can place your order with that distributor.
Background
The Lincoln Electric Welder AC-225 is an AC (alternating current) welder produced by Lincoln Electric. The welder uses standard electrode sticks and is capable of providing up to 225 amps of output power. It operates on a power source of 240V, 1-phase, 60 Hz AC. The output range of this welder is from 30-225 amps. It has an open circuit voltage of 79V and weighs 92 lbs. The dimensions of the welder are 20 x 12 x 15 inches.
The AC-225 welder is suitable for stick welding both ferrous and non-ferrous metals. The welder is equipped with a feature of continuous amperage control that enables the output to be finely adjusted to accommodate different electrodes and material thicknesses. The welder has a copper wound transformer that ensures a stable arc performance. Additional features include a front-mounted amperage meter for monitoring welding current, an overload protection light, and a resistant case. The welder comes with a 6.5ft electrode cable and a 6.5ft work cable. It can weld material up to 3/16 inches thick using E6010 and E7018 electrodes. The welder is suitable for a range of applications including general repair and maintenance, fabrication, construction, and hobby welding. The AC power enables it to weld common metals that include mild steel, stainless steel, cast iron, and nickel alloys.
Technical Specifications
  • Model Number: AC-225
  • Product: Lincoln Electric Welder AC-225
  • Product Type: Welder
  • Power Source: 240V, 1-phase, 60 Hz AC
  • Output Range: 30-225 amps
  • Duty cycle at 225A: 30%
  • Open Circuit Voltage: 79V
  • Dimensions: 20 x 12 x 15 inches
  • Weight: 92 lbs
  • Amperage Control: Continuous, adjustable from 30-225A
  • Transformer: Heavy-duty copper wound
  • Cable Length: 6.5ft electrode cable and 6.5ft work cable
  • Overload Protection: Yes, with indicator light
  • Case: Shock resistant
  • Amp Meter: Front mounted, easy to read
  • Additional Components: Comes with a stick electrode holder, work clamp, and 230V plug
  • Material Compatibility: Can weld material up to 3/16 inches thick using E6010 and E7018 electrodes. Suitable for mild steel, stainless steel, cast iron and nickel alloys.
Warranty
The Lincoln Electric Welder AC-225 comes with a warranty that lasts for 3 years. This warranty covers both parts and labor, ensuring that any issues with the welder during this period will be taken care of. To claim this warranty, it's required to reach out to authorized service centers by Lincoln Electric which are conveniently located all over the United States. It's important to remember to keep any relevant paperwork or receipts that prove your purchase, as this may be required when claiming your warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 1,059
