No Image
This wiki is missing a device image. Help improve this page by uploading one!
7 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
12200
Important Information
WCTA is no longer supplying 9S repair/replacement parts. Please contact Lincoln directly at 888-935-3876 and select option 1 for repair parts. They can work to insure you have the correct repair part as well as offer a Distributor in your area so you can place your order with that distributor.
Background
The Lincoln Electric Welder 12200 is an arc welder produced by Lincoln Electric. This AC/DC multiprocess welder is intended for use in fabrication and manufacturing environments. The welder can be connected to three primary inputs of power: 230V, 460V, or 575V. The output is rated at 300A at 32VDC with a 60% duty cycle. It caters to different welding processes including Stick (SMAW), DC TIG (GTAW), MIG (GMAW), and Flux-Cored (FCAW).
The Lincoln Electric Welder 12200 is equipped with a number of features. It includes a multi-voltage plug, a fan-as-needed system which reduces noise and energy use, and tool-less drive roll access for quick changeover. Additionally, it has a full color LCD screen for navigating the interface and enhanced diagnostics to provide troubleshooting assistance. This welder is designed for industrial welding applications and can produce quality welds in production environments.
Technical Specifications
  • Model Number: 12200
  • Product Type: Arc Welder
  • Manufacturer: Lincoln Electric
  • Year of Production: Since 2019
  • Input Power: 230/460/575V, 3-Phase
  • Rated Output: 300A at 32VDC, 60% duty cycle
  • Welding Processes: Stick (SMAW), DC TIG (GTAW), MIG (GMAW), Flux-Cored (FCAW)
  • Wire Feed Speed: 50-700 ipm
  • Max Spool Size: 12 in
  • Dimensions: 30 x 19 x 40 in
  • Weight: 375 lbs
Warranty
The Lincoln Electric Welder 12200 is accompanied by a warranty that lasts for three years. This warranty covers both parts and labor, ensuring that any issues or malfunctions that arise from the manufacturer's side within this period are dealt with at no extra cost. To claim this warranty, you should reach out to Lincoln Electric's network of authorized service centers. These centers are equipped to provide all the necessary service and support you might need while having the advantage of being directly authorized by the company.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 32
All Time: 340
