Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
18 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
ES8000E
Background
The Lifan Generator ES8000E is a gasoline-powered generator designed to provide portable power solutions. This generator has a 420cc Lifan OHV 4-stroke engine and is capable of providing 8000 watts of continuous power, with a surge capacity of 9000 watts. The fuel tank has a capacity of 6.6 gallons, which allows it to operate for up to 11 hours at 50% load. The noise level remains under 69 decibels even when operating at full capacity.
The generator is equipped with a range of outlets to cater to different power needs. These include two 120V 20A outlets, one 120V 30A outlet, and one 120V/240V 30A outlet. The generator also features a low oil shutoff sensor and an electric start system with recoil backup. The control panel features a voltmeter, circuit breakers, and a low oil indicator. With a weight of 202 lbs, the generator is designed for ease of portability, with built-in wheels and foldable handles. It produces power with less than 5% total harmonic distortion, making it suitable for running sensitive electronics.
Technical Specifications
  • Model Number: ES8000E
  • Product Type: Portable Gasoline Powered Generator
  • Continuous Power: 8000 watts
  • Surge Power: 9000 watts
  • Engine: 420cc OHV 4-stroke
  • Fuel Tank Capacity: 6.6 gallons
  • Runtime at 50% Load: Up to 11 hours
  • Noise Level: Less than 69 dB at no load
  • Outlets: Two 120V 20A outlets, one 120V 30A outlet, one 120V/240V 30A outlet
  • Dimensions: 27 x 27 x 28 inches
  • Weight: 202 lbs
  • Additional Features: Electric start system with recoil backup, low oil shutoff sensor, voltmeter, circuit breakers, power outlets.
Warranty
The Lifan Generator ES8000E offers a 2-year limited warranty from the date of purchase. This warranty specifically covers defects in materials and workmanship. However, it's important to note that items subject to normal wear and tear such as spark plugs, air filters, and engine oil are excluded from this coverage. In order to claim the warranty, proof of purchase is mandatory. Also, keep in mind that the warranty is non-transferable, meaning it can't be passed on if the product changes hands.
Lifan Energy Storm ES3500–ES8000 Generator Operating Instructions and Owner's Manual
ES3500–ES8000E Portable Generators Owner's Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 44
All Time: 521
