No Answers 0 Score |
الحاسوب يسخن و يعلق كثير The computer gets hot and hangs a lot |
My PC has airplane mode turned on but it can't be turned off. Solution |
Documents
Background and Identifications
Lenovo is a Chinese technology company and manufactures an array of electronic products including personal computers, tablets, smartphones, storage devices, and many more. The ThinkPad line is Lenovo’s business-oriented brand that has seen significant success and has even been used in outer space. Their Edge series began in 2010 and was their small-business model. The Lenovo ThinkPad Edge 11 was Lenovo’s lightest and smallest ThinkPad Edge on the market, with an 11” display and a weight of 1.5kg. ZDNet states in this review on the Lenovo ThinkPad Edge 11, “At its entry-level price point, Lenovo's ThinkPad Edge 11, "gives top-end netbooks a run for their money, offering a capable processor, decent hard drive capacity and a screen of reasonable size and resolution. “
The Lenovo ThinkPad Edge 11 is available in a glossy red, glossy black, or matte black, and this color covers the outside of the laptop. The inside, however, is black for all the models, with hints of red, which is normal for a Lenovo Thinkpad. The ThinkPad logo can be found on the inside of the laptop on the bottom right, under the keyboard, and on the top-lid of the laptop. The serial number can be found on the bottom of the laptop.
Technical Specifications
Audio
- High Definition (HD) Audio
- Conexant CX20585 codec
- Headphone / Microphone combo jack
- Stereo speakers
Keyboard
- 89-keys
- TrackPoint Sensor with TrackPoint controller
- Touchpad supports multi-touch function
- Spill-resistant
- Multimedia Fn keys
Memory
- PC3-8500 Non-Parity (NP) Double Data Rate Three (DDR3) Technology
- Two SO-DIMM Slots
- The use of 1066 MHz SODIMM memory is recommended for this system.
- 1 GB or 2GB memory
- Supports up to 4GB maximum memory
''Note: Only 64-bit operating systems support more than 3GB of system memory (RAM).''
Mouse
- TrackPoint® pointing device, Internet Scroll Bar, magnifying glass
- UltraNav™, wide touchpad below keyboard, Tap Zones, multi-touch
Processor
- Available processors are:
- Intel® Celeron® Processor U3400 (1.06 GHz)
- 800MHz system bus, 2-MB L3 cache
- Intel® Core Processor i3-380UM (1.33GHz)
- 800MHz system bus, 3-MB L3 cache
- Intel® Pentium® Dual-core Processor U5400 (1.20 GHz)
- AMD Turion™ II Neo Dual-Core Processor K625 (1.5 GHz)
- 400MHz system bus, 2-MB L2 cache
- AMD Turion™ II Neo Dual-Core Processor K325 (1.3 GHz)
- AMD Athlon™ II Neo Processor K125 (1.7 GHz)
- 400MHz system bus, 1-MB L2 cache
Network
- Intel Centrino Advanced-N + WiMAX 6250
- Intel Centrino Wireless-N 1000
- ThinkPad 1x1 11b/g/n Wireless LAN PCI Express Half Mini Card Adapter
- ThinkPad 2x2 11a/b/g/n Wireless LAN PCI Express Half Mini Card Adapter
- Qualcomm Gobi2000 Wireless WAN card
- Bluetooth with Enhanced Data Rate (BDC-2.1)
External ports
- Three USB ports version 2.0
- 4-in-1 reader (MultiMediaCard, Memory Stick, Mem Stick Pro, Secure Digital)
- External monitor (VGA out, HDMI)
- Built-in RJ-45 connectors for LAN connection
- Combo microphone and headphone jacks
Physical specifications
For systems with an 11.6-in wide TFT display:
- System:
- Width: 284 mm
- Depth: 190 mm (3 cells) and 211 mm (6 cells)
- Height: 15.6 to 29.5 mm
- Configured system weight: Starting at 1.33 kg
- Environment:
- Maximum altitude without pressurization: 3048 m (10,000 ft)
- Temperature
- At altitudes up to 2438 m (8000 ft)
- Operating: 5.0°C to 35.0°C (41°F to 95°F)
- Non-operating: 5.0°C to 43.0°C (41°F to 109°F)
- At altitudes above 2438 m (8000 ft)
- Maximum temperature when operating under the unpressurized condition: 31.3°C (88°F)
- Relative humidity:
- Operating: 8% to95%
- Non-operating: 5% to 95%
Additional Information
- Lenovo ThinkPad Edge 11 Detailed Specifications
- Lenovo ThinkPad Edge 11 Review (Notebook Check)
- Lenovo ThinkPad Edge 11 Review (ZDNet)
Lenovo ThinkPad(Edge 11) 0328-2LV Intel 黑色機種詳細規格
Lenovo ThinkPad Edge 11-inch and E10 Hardware Maintenance Manual
Lenovo ThinkPad Edge 11 Laptop Product Brochure
Lenovo ThinkPad Edge 11" および E10 ハードウェア保守マニュアル
Lenovo ThinkPad Edge 11 and E10 Hardware Maintenance Manual
ThinkPad Edge 11", 13", 14" et 15" Guide de maintenance et d'identification des incidents
ThinkPad Edge 11" – Инструкции за настройка
ThinkPad Edge 11–15" Руководство по обслуживанию и устранению неполадок
Guía de servicio y de resolución de problemas de ThinkPad Edge 11", Edge 13", Edge 14" y Edge 15"
ThinkPad Edge 11, Edge 13, Edge 14, and Edge 15 Service and Troubleshooting Guide
Lenovo ThinkPad Edge 11" and E10 Hardware Maintenance Manual
