Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Technical Specifications
System:
  • Model Number: 16IRX9H
  • CPU: Intel Core i9-14900HX, 24 Core (8 Performance, 16 Efficiency), 32 threads, 2.2GHz Base/ 5.80GHz Turbo (Performance), 1.6GHz Base/4.1GHz Turbo (Efficiency)
  • CPU Cache: 36MB L3, 32MB L2, 2.1MB L1
  • CPU Power: 55w base, 125w PL1, 185w PL2 (Default)
  • Integrated Graphics: Intel UHD 770 for 14th Generation Intel Processors, 1.65GHz clock, 32 Execution Units, 15w TGP
  • GPU: Nvidia Geforce RTX 4080 Laptop GPU (12GB, 2280MHz boost, 175w TGP)*, Nvidia Geforce RTX 4090 Laptop GPU (16GB, 2040MHz boost, 175w TGP)*
  • Chipset: Intel HM770
  • Monitor Support: 4 (Internal + 3 External via HDMI and USB-C)
  • Memory: DDR5, 2 SODIMM Slots, 32GB DDR5-5600 max offering, up to 192GB*
  • Storage: 2xNVMe M.2 2280 Slots, PCIe 4.0 x4, 1TB (Samsung 980 Pro OEM), up to 4TB per slot*
  • Battery: 80Wh or 99.9Wh
  • Audio Chip: Realtek ALC3306
  • Speakers: Stereo speakers (super linear speaker), 2W x2, audio by HARMAN, optimized with Nahimic Audio, Smart Amplifier (AMP)
  • Display: 16in 2560x1600 IPS Anti-glare, 1200:1 contrast ratio, 100% DCI-P3, 240Hz, 10 bit, DisplayHDR™ 400, Dolby Vision®, NVIDIA® G-SYNC®, Advanced Optimus support, TÜV Rheinland® Low Blue Light, TÜV Rheinland® High Gaming Performance, 89° Viewing Angle, 500 nits, X-Rite Color Calibration
  • Keyboard: 6-row, multimedia Fn keys, numeric keypad, key travel 1.5mm, cap recess 0.3mm, Per-key RGB backlight (with lighting lens on the front side) or White backlight
  • Touchpad: Buttonless Mylar® surface multi-touch touchpad, supports Precision TouchPad (PTP), 75 x 120 mm (2.95 x 4.72 inches)
  • Camera: FHD 1080p, with E-shutter, fixed focus or HD 720p, with E-shutter, fixed focus
  • Microphone: Dual Microphone array
  • Operating System: Windows 11 Pro, Home, or No OS
  • Cooling: Vapor Chamber, Liquid Metal (CPU), PTM7958 (GPU), Dual Fan (Air)*
I/O:
  • 4x USB-A 3.2 Gen 1 (5Gbps), 2nd port on back is always on at 5v 2a
  • 1x USB Type-C 3.2 Gen 2 (10Gbps), PD 140w, Displayport 1.4, 4K 60Hz
  • 1x Thunderbolt 4 (40Gbps, PCIe), USB4 (40Gbps), Displayport 1.4, 4K 60Hz
  • 1x HDMI 2.1, up to 8K 60Hz
  • 1x Headphone jack (Combo Mic/Stereo Audio)
  • 1x Gigabit Ethernet (Realtek RTL8168)
  • 1x Lenovo Slim Tip Power Connector, 330w
Design:
  • Dimensions: 363.5 x 262.1 x 21.95-25.9 mm (14.31 x 10.32 x 0.86-1.02 inches)
  • Weight: Around 2.62 kg (5.78 lbs)
  • Case Color: Eclipse black
  • Case Material: Aluminium (top), aluminium (bottom)
Connectivity:
  • WLAN + Bluetooth: Wi-Fi® 6E, 802.11ax 2x2 Wi-Fi® + Bluetooth® 5.3, M.2 card or Intel® Killer™ Wi-Fi® 6E AX1675i, 802.11ax 2x2 Wi-Fi® + Bluetooth® 5.3, M.2 card
  • Ethernet: Gigabit Ethernet, 1x RJ-45, supports Wake-on-LAN, Realtek RTL8168
Features:
  • Tobii Eye Tracking
  • AI Chip: LA2-Q
  • TPM 2.0
  • Self-healing BIOS
Notes:
  • Using more than 32GB of RAM will lower the memory speed from 5600MT/s to 5200MT/s
  • Dual sided SSDs are not supported
  • The RTX 4080 Laptop GPU is based on AD104, and the 4090 Laptop GPU is based on AD103
  • Comes pre-installed with McAfee Livesafe
  • Nahimic, the audio software this device comes with, is known to be difficult to remove if the user does not wish to have it. It often behaves like malware, and a successful attempt at uninstalling usually renders the audio inoperable.
  • Lenovo Vantage is pre-installed on this device, however, the community generally recommends Lenovo Legion Toolkit (a 3rd party toolkit) instead, as Vantage can be privacy invasive
  • PTM7958 isn't available to normal consumers, however, PTM7950 is the closest alternative to PTM7958 that is available to consumers should you need it.
  • Be VERY careful when dealing with Liquid Metal. Liquid Metal is conductive, and if you do end up getting any on the board, you run a high risk of killing the device. You should not touch the liquid metal cooling unless you are sure you know what you are doing
  • Keyboards on this device can sometimes fail, while it does not affect every model, some have issues with trace failure.
  • Can be tricky to use with Linux, especially due to Nvidia GPUs limiting themselves to 80w, it is however possible to set it to 175w.
  • The bottom of the laptop can be hard to pry open due to strong plastic clips, you may need to use a bit of force to pull off the bottom. Do not use excessive force, however, you may damage parts of the device that way.
Lenovo Legion Pro 7i (16", 9) User Guide
Lenovo Legion Pro 7i (16", 9) Hardware Maintenance Manual
Lenovo Legion Pro 7i (16-inch, 9) Getting Started Instructions (EN, ES, BG, PT, PL)
Legion Pro 7i (16", 9) Setup Guide (EN, ZH, JA, KO)
Author
with
Lyra Heart
135 Reputation
0 Guides authored
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 79
All Time: 298
