Up to 20% off select tools
Guides
Documents
Models
82M7
Ideapad Flex 5 Chromebook En Hmm
Background
The Lenovo IdeaPad Flex 5 Chromebook is a 2-in-1 device, meaning it has both laptop and tablet-like operating modes. It runs on Google ChromeOS and is commonly used in academic, home, and light office average budget-conscious consumer settings. It was released in May of 2020 as a part of Lenovo’s IdeaPad Flex series and is often referred to as the IdeaPad Flex 5 or Flex 5 Chromebook.
Production regarding this particular model was phased out around 2022-2023, as newer models released, however it was widely available internationally during its release. This model sits in the mid-range of the IdeaPad Flex Chromebook lineup, offering better build quality and performance than earlier models, but not as premium as higher-end Flex laptops running Windows.
Consumer reviews tend to mention the following features/issues:
Common Praises:
  • Solid build quality for price
  • Good performance for ChromeOS tasks
  • Comfortable keyboard
  • Bright display
Common Complaints:
  • Limited internal storage (common with Chromebooks)
  • Limited upgradeability
  • Occasional touchscreen or hinge durability concerns (common with 2 in 1 devices)
A main feature of the IdeaPad Flex 5 Chromebook is its 360-degree hinge, the 2 in 1 aspect of its design, which allows the device to operate in laptop, tablet, or standing mode. It should be noted that because of the 2 in 1 design of this device, it has more repair considerations than a device without these features, such as hinge stress or touchscreen unresponsiveness. The prioritization of a sleek look and portability in this device may also work against it, as its thin chassis also means internal components are very closely arranged or soldered together, which can affect ease of access during disassembly and repair as well as limit upgrading options.
Some retailers, such as Lenovo and Amazon no longer list the IdeaPad Flex 5 Chromebook for purchase, in favor for newer laptops apart of the Flex series, or similar. However, other sites list it as still available, for around $400.
Sources:
Identification
The model number and machine type of this device are printed on a label nearing the left side of the bottom of the laptop and can also be found when operating the computer, under Settings →  About ChromeOS.
The Lenovo IdeaPad Flex 5 Chromebook (13”) 2-in-1 laptop is a slim device (Dimensions (H x W x D): 310mm x 214mm x 17mm / 12.2" x 8.42" x 0.66") with a 13-inch touchscreen and a 360-degree hinge that allows it to fold into laptop, tablet, or standing positions. It is dark grey/graphite in colour and has a Lenovo logo on its lid.
The device can be identified further by its power button, volume key, USB-C charging port and Kensington security lock slot on its right side, and its USB-C charging port, USB-A port, headphone jack and MicroSD card reader slot on its left side.
Pressing “alt+v” on the login screen will display the serial number as well as other info.
Further details about the device that may aid in identification are included within the technical specifications information listed below.
Sources:
Technical Specifications
General
  • Processor: 10th Generation Intel® Core™ i3-10110U Processor (2.10 GHz, up to 4.10 GHz with Turbo Boost, 2 Cores, 4 Threads, 4 MB Cache)
  • Operating System: Chrome OS 64 bit
  • Display: 13.3” FHD (1920 x 1080) IPS, glossy, touchscreen, 250 nits
  • Memory: 4 GB DDR4 2667MHz (Soldered)
  • Graphics: Integrated Intel® UHD Graphics
  • Battery: Up to 10 hours*
    • *Battery life is based on power testing (also known as the power_LoadTest, or PLT).
    • Battery life varies significantly with settings, usage, and other factors.
  • Storage: 128 GB PCIe SSD
  • Audio: 2 x front-facing 2W speakers
  • Camera: 720p with microphone array
  • Connectivity:
    • 802.11AX (2 x 2)
    • Bluetooth® 5.0
  • Ports/Slots:
    • 2 x USB-C 3.2** (Gen 1)
    • USB-A 3.2 (Gen 1) (PowerDelivery)
    • Headphone / mic combo
    • MicroSD card reader
Physical Attributes & Extras
  • Dimensions (H x W x D): 310mm x 214mm x 17mm / 12.2" x 8.42" x 0.66"
  • Weight: Starting at 2.97lbs (1.35 kg)
  • Color: Graphite Grey
  • Pen: Sold separately
Sources:
Additional Information
Lenovo IdeaPad Flex 5 Chromebook (13-inch, 05) User Guide
Lenovo IdeaPad Flex 5i Chromebook (13", 6) User Guide
Lenovo IdeaPad Flex 5 Chromebook (13", 05) ユーザー・ガイド
Author
with
Ben Lefebvre
191 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 68
All Time: 1,480
