Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Released in May 2022, the Lenovo IdeaPad Duet 3 Chromebook 11Q727 is a laptop-tablet hybrid that runs on ChromeOS. With a weight of 1.2 lbs (2.1 lbs with the cover), it was designed to be a highly portable, lightweight device ideal for leisure, light productivity tasks, and web browsing. It can be purchased with either 4 GB or 8 GB of memory, and in the colors Storm Gray or Misty Blue. The device is manufactured by Lenovo and can be purchased from their website for $379. The device has an 11" 2K IPS touchscreen, a fully detachable keyboard, and a protective faceplate. The Duet 3 Chromebook has a 5 MP front-facing camera and an 8 MP rear-facing camera. Its 2 USB-C ports can be used for charging or for attaching accessories such as an optical mouse or larger display monitor. While the device has no headphone jack, it has fully functional Bluetooth capability. With an estimated 10.5 hours of battery life and recharge time of an hour, battery is unlikely to be a major concern for most users. The device also has an easily replaceable keyboard and faceplate, which can be customized by third-party manufacturers if desired.
With its affordability and portability, the Duet 3 Chromebook is ideal for students and remote workers needing a functional device for productivity or leisure without the hassle of a heavier laptop. It handles web-based applications on Google Chrome relatively well. It also tends not to overheat, so in-lap usage is generally comfortable. However, users needing a device for more intense gaming or desktop apps such as Microsoft Suite may be better served by alternatives, such as full-sized laptops.
Identification
The Lenovo IdeaPad Duet 3 Chromebook can be identified by its 11-inch touchscreen, detachable keyboard, and thin, lightweight design. The specific model number, 11Q727, is typically located on the back of the tablet portion of the device, near the product label. This model should not be confused with the original Lenovo Chromebook Duet (10.1") or the Duet 5 Chromebook, both of which differ in size and hardware specifications. The 11Q727 has squared corners, a minimal bezel, and usually ships in Storm Grey.
Technical Specifications
Processor
  • Qualcomm Snapdragon 7c Gen 2 (Octa-core, up to 2.55GHz)
Operating System
  • ChromeOS
Graphics
  • Qualcomm Adreno GPU
Display
  • 10.95" 2K IPS Touchscreen (2000 x 1200)
  • 400 nits' brightness
  • 15:9 aspect ratio
  • 70.8% NTSC color gamut
  • TÜV Low Blue Light (software solution)
Memory
  • 4GB or 8GB LPDDR4x (soldered)
Storage
  • 64GB or 128GB eMMC 5.1 (non-upgradable)
Audio & Video
  • Stereo speakers (1W x 2)
  • Dual microphone array
  • 5MP front-facing camera
  • 8MP rear camera
Battery
  • 29Wh integrated Li-Polymer battery
  • Up to 12 hours battery life
Power Adapter
  • 30W USB-C AC Adapter (100-240V)
Input Devices
  • Detachable non-backlit keyboard (Pogo pin)
  • Multi-touch trackpad
  • USI pen support (sold separately)
Dimensions & Weight
  • Tablet: 258.04 x 164.55 x 7.9 mm
  • Tablet weight: ~1.14 lbs.
  • Total weight with keyboard: ~2.09 lbs.
Ports
  • 2 x USB-C 3.1 Gen 1 (DisplayPort & Power Delivery)
  • 1 x Pogo pin connector
Connectivity
  • Wi-Fi 5 (802.11ac, Dual Band)
  • Bluetooth 5.2
Sensors
  • Accelerometer
  • Gyroscope
  • Hall sensor
Security
  • Google Security Chip H1
Certifications
  • ENERGY STAR 8.0
  • ErP Lot 6/26
  • RoHS compliant
  • TÜV Rheinland Low Blue Light
Sources:
Additional Information
Complete Teardown Guide
Device Manual
Device Review Guide
Judah
333 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 94
All Time: 1,058
