Battery
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
82AT, 82HK
Background
The Lenovo IdeaPad Duet 3 10IGL5, also marketed as the IdeaPad Duet 3i, was released in 2020 at a retail price of $400 - $500. It is part of Lenovo’s IdeaPad Duet line as a compact and detachable Windows product. The tablet is small and portable with a 10.3-inch touchscreen, detachable keyboard, and built-in kickstand. It was designed to be a lightweight and less bulky alternative to larger laptops while still giving users the flexibility to use it as both a tablet and a small laptop. That flexibility was one of its main selling points, since it allowed users to switch easily between both a tablet and a laptop depending on what they needed.
The Lenovo IdeaPad Duet 3i’s technical functionality was also designed as a blend between a laptop and tablet. Instead of promising high performance, it focuses more on portability, touchscreen use, detachable components, and everyday convenience. It is better suited for lighter workloads such as schoolwork, internet browsing, streaming, and note-taking rather than more demanding tasks like gaming or heavy multitasking. Its compact size makes it easy to carry around and use in different places, which helped make it appealing to students and other users looking for a simple everyday device. It was marketed as a practical and inexpensive option for users who wanted a basic Windows device that could handle normal daily tasks without the size and weight of a traditional laptop.
There has been no official public recall for this device, but Lenovo stopped production sometime in 2023 after the release of IdeaPad Slim and Yoga Slim models. Because this device relies on detachable parts, it being carried around frequently makes the components more susceptible to wear and tear. Common issues customers encounter with this model include overheating, low performance, and battery degradation.
Identification
The Lenovo IdeaPad Duet 3 10IGL has a slim tablet-style body with a front camera centered above the display at the top of the device, and a rear camera on the back of the device. You can find the power and volume buttons along the right side of the tablet. The USB-C ports, SD card slot, and headphone jack are located on the left side of the device. There are vents located at the top corners on each side of the tablet. The manufacturing details of the device can be found under the device's stand or within the system settings. If your device also has a keyboard, you can locate the Bluetooth connection to the bottom right corner of the keyboard. The device is commonly a graphite color.
Technical Specifications
Tablet
- Dimensions: 9.96” x 6.59” x 0.39” in.
- Weight: 1.32 lbs.
- AC Power Input: 100 V ac–240 V ac, 50 Hz–60 Hz
- AC Power Output: 20 V dc, 2.25 A
- Battery Capacity: 30 Wh
- Battery Cell Count: 2
- Microprocessor: Intel processor N4020
- Memory Type: Onboard, 0 additional slots
- Storage Device Type: eMMC 5.1
- Screen Size: 10.3”
- Display Resolution: 1920 × 1200 pixels
- Ethernet: not onboard
- WLAN: 802.11ac 2x2 Wi-Fi®
- Charging Port: USB-C 3.2 Gen 1
Bluetooth Folio Keyboard
- Weight: 0.59 lbs.
- Features: Function keys, Hotkeys, Bluetooth switch, Trackpad
Source: Lenovo IdeaPad Duet 3 10GL5 Specifications
