Up to 20% off select tools
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
1.107-184.0
Background and Identification
Landa is a company that sells a variety of industrial cleaning machines and accessories, including pressure washers. These machines can be used in many different industries for many applications, depending on their strength, which is usually measured by the pressure (PSI, or pounds per square inch) that they can exert on an area. With high enough pressure, these machines can remove paint, mold, dirt, and other substances from decks, roofs, sidewalks, and much more. Landa products come from a variety of manufacturers.
This cold water pressure washer can reach a pressure rating between 3500 and 4000 PSI, making it a higher-end pressure washer. It includes several different connecting nozzles, which can be used to spray at different angles or to use with detergent for more intense cleaning. It is also CSA Safety Listed. This means that it meets certain safety standards made by the CSA Group, an independent safety standards association that certifies products in the United States and Canada.
Technical Specifications
  • Engine: Honda GX390
  • Assembled Depth: 40 in
  • Assembled Height: 27 in
  • Assembled Width: 23 in
  • Weight: 125 lbs
  • Pressure: 3500 PSI
  • 3.5 GPM
  • Direct drive triplex piston AR Pump
  • Hose Dimensions: 50' x 3/8"
  • Lance Dimensions: 36"
Additional Information
Home Depot Rental
Landa Home Page
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 40
All Time: 2,411
