Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
PC3-3000
Background
The Landa Pressure Washer PC3-3000 is a gas-powered pressure washer suitable for commercial and industrial cleaning applications.
The Landa PC3-3000 is a cold water pressure washer with a 223cc Honda GX200 engine. It has a pump pressure of 3000 PSI and a water flow rate of 3.5 GPM. The pump is an axial cam pump made of brass with a thermal relief valve to prevent overheating. The washer is designed with a steel frame and 13" pneumatic tires for mobility. It includes a 50 ft high-pressure hose and a variable pressure wand with quick connect spray tips. The spray tips include 0°, 15°, 25°, and 40° for various cleaning tasks. Additional features include an integrated detergent tank and an easy-start valve for simplified pull starting. The washer weighs approximately 200 lbs dry.
The Landa PC3-3000 pressure washer is intended for commercial cleaning businesses and industrial facilities. Its applications include cleaning buildings, floors, walls, roofs, removing paint, rust, grease, oil and other difficult dirt, cleaning parking lots, sidewalks, loading docks, cleaning trucks, heavy equipment, agricultural equipment, graffiti removal, and preparing surfaces for painting. With a pump pressure of 3000 PSI and high flow rate, it is capable of handling tough cleaning jobs. The Honda engine provides reliable power for continuous use.
Technical Specifications
  • Model Number: PC3-3000
  • Product Type: Pressure Washer
  • Power Source: 223cc Honda GX200 engine
  • Pump Pressure: 3000 PSI
  • Water Flow Rate: 3.5 GPM
  • Pump Type: Axial cam pump with brass head
  • Power Drive: V-belt drive
  • Fuel Type: Gasoline
  • Fuel Tank Capacity: 1.1 gallon
  • Detergent Tank Capacity: 1/5 gallon
  • Hose Length: 50 ft
  • Hose Diameter: 3/8"
  • Spray Tips: 0°, 15°, 25°, 40°
  • Frame Material: Steel
  • Wheel Size: 13" Pneumatic
  • Weight (Dry): ~200 lbs
  • Product Dimensions: 48" x 26" x 31"
Warranty
The Landa Pressure Washer PC3-3000 comes with a limited 1-year consumer warranty. This warranty covers any defects in materials and workmanship that may arise within 1 year from the date of purchase. However, it is important to note that the warranty does not cover normal wear items such as hoses, spray tips, and tires. The engine of the pressure washer is covered separately by a warranty from Honda. To claim the warranty, you would need to contact the manufacturer or the place of purchase, provide proof of purchase, and describe the issue that has occurred.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 24
All Time: 372
