1 Answer 0 Score |
LG Dishwasher HE error code. What is this part? |
No Answers 0 Score |
Broken Part ID Help |
Top water propeller isn’t working. No water coming through and it mak |
Documents
Background
The LG LDF5545 is a 24 inch built in front control dishwasher manufactured by LG Electronics and was introduced in 2016 as part of LG's Quadwash Dishwasher Lineup. This was designed to provide homeowners with an efficient and quiet wat to clean dishes while offering several washing options. Some of the major features included are the Nine wash cycles, eight additional wash options, a stainless steel interior, and a 15 place setting capacity. One of the notable features is the LG Quadwash Technology which uses four spray arms instead of the traditional two to spray water from multiple angles this along with an EasyRack plus system that allows users to adjust the racks to accommodate different sizes of dishes pots and pans.
The LDF5545 Is part of LG's larger family of Quadwash dishwashers which included several models and different control styles or features. IT was designed as a front control model which means the buttons and display are located on the front of the dishwasher door. Other products in the same family offer top mounted controls and additional features but the LDF5545 was designed with affordability in mind rather than the higher price point models.
Like other models the LDF5545 can experience mechanical, electrical, and plumbing related problems over time with common problems being drainage failures or water leaks. One noteworthy issue involved moisture damage to the control panel circuity which was documented in a service bulletin covering certain production dates, these problems can affect the dishwashers ability to operate correctly and may require troubleshooting, cleaning or replacement of the component. While there are reports of the problem it does not mean that every model of the LDF5545 will experience the same problems
The LDF5545 model is also available under several product variations those being:
- LDF5545ST- Stainless Steel
- LDF5545BD - Black Stainless Steel
- LDF5545B-Black
- LDF5545WW- White
- LDF5545SS - PrintProof Stainless Steel
To verify that you have the correct dishwasher, open the door and locate the manufacturer's identification label along the right edge of the door. This label contains the model and serial numbers. Check that the model number begins with LDF5545 and that the finish suffix matches your particular unit. Using the complete model number is important when locating repair diagrams, replacement parts, and service documentation.
Technical Specifications:
Manufacturer: LG Electronics
Model:LDF5545
Appliance Type: Built In Front Control Dishwasher
Capacity: 15 Place Settings
Interior Tub: Neverust Stainless Steel
Noise Level:48dBA
Weight : Approximately 75 lbs
Dimensions:
- Width:23.75 inches
- Height:33.6 Inches
- Depth: 24.6 Inches
- Depth With Door Open:50.5
Cleaning System:
- QuadWash Technology
- Three Spray Nozzles(Top, Upper, and Lower)
- Three-Stage Filtration system
- SenseClean Wash System
- Hidden Water Heater
- Hybrid Condensing Drying System
Wash Cycles
- Auto
- Heavy
- Delicate
- Normal
- Turbo
- Download Cycle
- Machine Clean
- Rinse
- Express
Wash Options:
- Dual Zone
- Half Load
- Energy Saver
- High Temperature
- Extra Dry
- Delay Start
- Control Lock
- Night Dry
Electrical and Water Requirements
- Electrical requirement: 120v, 60Hz AC
- Recommended Circuit Protection: Minimum 15A Circuit Breaker
- Water Pressure:20-80PSI
- Min Inlet Water Temperature 120F
- Max Inlet Water Temperature 149F
Additional Information
Note: There are moisture related control panel problems that are worth included because it is a service issue affecting the LFG5545
LG LDF5545 Front Control Dishwasher Product Information
LG LDF5545 Series Front Control Dishwasher with QuadWash Specifications
LG LDF5545 Part Diagrams
