Guides
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
600DD-S
Background and Identification
The Kushlan Cement Mixer 600DD-S (UPC number 6048040020260) is a direct drive wheelbarrow style cement mixer that features a 0.75-horsepower electric motor. The mixer’s engine provides 28 rotations per minute on 120 Volts. The mixer can hold up to four 80-pound bags of premixed concrete, or over 300 pounds. Kushlan generally recommends adding approximately five gallons of water for four-80-pound bags of premixed concrete.
The 600DD-S features heavy-gauge steel handles that retract for easier storage. The mixer weighs 107 pounds without any cement in the drum. It features three steel blades with a mortar or concrete configuration. The mixer’s polyethylene drum is 5/16-inch thick and is resistant to dent, cracks, and rust.
The 600DD-S model is a wheelbarrow style mixer, meaning that it has handles and wheels (somewhat like a wheelbarrow) for moving the mixer. It includes a heavy gauge black steel frame and polyurethane flat-free tires. The polyethylene drum is a bright orange color. The drum’s opening is 17 inches across and is 26 inches in diameter at its widest point. The stand’s wheels are black and the tires are either grey or bright orange. A black sticker with the name “Kushlan Products LLC” in white font is located on the side of the mixing drum.
Technical Specifications
  • Polyethylene Drum
  • ​​Functioning Height: 46”
  • ​Functioning Length: 50″
  • ​Functioning Width: 24″
  • ​​Functioning Weight: 107 lbs.
  • ​Drum Diameter: 26″
  • ​​​Drum Opening: 17″
  • ​Drum Gauge: 5/16″
  • ​Drum Rotations: 28 RPM
  • ​​5-6 Bags of 60 lbs. Premixed Concrete
  • ​Steel Tubing Frame, Cold Rolled Galvanized Steel​
  • ​3 Steel Blades with Mortar/Concrete Configuration
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 13
Past 7 Days: 58
Past 30 Days: 257
All Time: 20,485
