Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Krups 203 coffee grinder is the least expensive of the four coffee grinders Krups produces. For this reason, Krups generally recommends that you simply replace a broken grinder. A standard load will produce up to 12 cups of coffee. The 203 grinder is the only Krups grinder that only has a pulse button; all of the other grinders Krups produced have extra settings. The easiest way to identify if you have a Krups 203 grinder is to look at the bottom. There will be a sticker with “Krups” and “Type 203” written on it.
Technical Specifications
Product Dimensions: 3.5 x 3 x 6.8 inches
Weight: 1 pound
Item model number: 1500813253
Troubleshooting
For information on common problems with your coffee grinder, refer to the Krups F203 Coffee Grinder Troubleshooting guide.
Additional Information
Krups F203 Manual
Replacement Parts
How to Solder Video
Krups F203 on Amazon
KRUPS Fast Touch Grinder F 203 Instructions for Use
Krups F203 Coffee Grinder Instructions
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 178
All Time: 25,945
