Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
This device can be used to test to verify the voltage from USB-A & USB-C ports along with the current being drawn and the watt-hours of a device plugged into it.
NOTE: This will measure voltage on a USB-A port with no load attached but it must have a USB-C load attached to check a USB-C port.
  • 3 to 20V DC; Current: 0.05 to 3A (USB-A); 3 to 20V DC; Current: 0.05 to 5A (USB-C)
  • Continuously monitor up to 1000 hours of voltage, current, capacity/charge delivered, energy, and resistance (calculated)
  • Tests most common standard USB-A or USB-C ports, including Qualcomm Quick ChargeĀ® ports
  • Store and recall up to 10 readings
  • Voltage and current overload detection
  • Hi-resolution LCD for clear visibility in environments with low ambient lighting
  • Device must be used in line between source being measured and power source
  • Rugged, pocket-sized, and light weight Klein industrial design stands up to jobsite demands
  • Built to withstand a 6.6-Foot (2m) drop
  • No batteries needed; powered by the USB port being tested
Klein Tools ET920 USB Type-A and Type-C Digital Meter Instruction Manual
Author
with
rickwag
1,906 Reputation
15 Guides authored
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 77
All Time: 759
