Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Keychron K2 Wireless Mechanical Keyboard is a compact 75%-layout keyboard released in 2019, designed to offer a balance of portability and mechanical performance. It features 84 keys, Bluetooth and USB-C connectivity, and can pair with up to three devices at once. The K2 comes in plastic or aluminum frames and offers multiple mechanical switch options for different typing preferences. Its large 4000 mAh battery provides long-lasting use, especially with the backlight off, and it includes RGB or white LED lighting, Mac-friendly keycaps, and built-in multimedia shortcuts. The K2 later led to updated versions like the K2 Pro and K2 Max, which added hot-swappable switches and greater customization.
In terms of reliability, common user-reported failure modes include Bluetooth connectivity issues (such as random disconnections or difficulty pairing), battery degradation over time, and individual key switch failures after extended use. Some users have also reported issues with the USB-C charging port becoming loose or unresponsive. Additionally, because earlier versions were not hot-swappable, replacing a faulty switch required soldering, which increased repair difficulty. Later models addressed this limitation.
Identification
If you look on the back middle of the keyboard, you should find a label specifying the type of keyboard. This label should say, "Keychron K2 Wireless Mechanical Keyboard" with the manufacturer and the serial number.
You can also distinguish the K2 from similar Keychron models by its 75% layout with 84 keys, which includes a compact arrangement of arrow keys and a tightly grouped function row. Unlike the K6 (which has a 65% layout and no dedicated function row), the K2 includes full F1–F12 keys. Additionally, the K2 has side switches on the left for Bluetooth/Wired mode and Mac/Windows compatibility, along with a USB-C charging port. These physical features, combined with the model name on the back label, will help you confidently identify the correct keyboard before beginning any troubleshooting or repair.
Technical Specifications
Number of keys: 84
Switch type: Mechanical/Optical Switch
Battery: 4000mAh
Battery Life: ~70 hours with backlight on
Charging Time: ~3 hours to full charge
Charging Port: USB Type-C
Mode: Both Bluetooth and wired functionality
Bluetooth operating distance: Within 10 meters in open space
Name of Bluetooth Device: Keychron K2
Operating Environment: -10 to 50 degrees Celsius
Additional Information
Keychron K2 Bluetooth Mechanical Keyboard Quick Start Guide
Author
with
Zachary Miller
247 Reputation
0 Guides authored
Texas Tech, Team 11-4, Weston Spring 2026 Member of Texas Tech, Team 11-4, Weston Spring 2026
TTU-WESTON-S26S11G4
4 Members
0 Guides authored
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 158
All Time: 744
