Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Keychron K10 Max Wireless is part of Keychron’s K Max series and is designed for users who want a full-size mechanical keyboard with flexible connection options. It uses a 100% layout, which means it includes the full set of standard keys, including the function row, arrow keys, and number pad. This makes it a practical choice for users who prefer a traditional keyboard for typing, schoolwork, office tasks, gaming, or general everyday use.
Compared to more compact keyboard layouts, the full-size design gives users access to all keys without relying as much on shortcuts or secondary functions. The Keychron K10 Max Wireless is built for people who want the familiar feel of a standard desktop keyboard while still having the option to use it wirelessly or through a wired connection.
One thing that makes this keyboard unique to others is the tools that come with this device. It is common to see other keyboards come with nothing, whereas this device comes with a keycap puller/mechanical key switch puller, an Allen wrench, and a Phillips screwdriver for future repairability. This is a great addition for any users for anyone who need to do maintenance on their device.
Identification
The easiest way to identify the Keychron K10 Max Wireless is by its name and full-size design, which includes a number pad. It should not be identified only by whether it works with Windows or macOS, since it supports both and that does not make it unique. The best way to confirm the model is by checking the label on the keyboard, the packaging, or official product information from Keychron. Its full-width layout also helps separate it from smaller keyboard models.
Technical Specifications
General Specifications
  • Number of Keys: 108 (100% layout)
  • Layout: ANSI
  • Switches:
    • Keychron Super Mechanical
    • Keychron Apex Mechanical
  • Switch Orientation: South-facing
  • Multimedia Keys: 12
  • Frame Material: ABS
  • Keycap Material: Double-shot PBT
  • Keycap Profile: OSA (OEM profile with spherical angle)
  • N-key Rollover (NKRO): Yes, in both wireless and wired modes
Connectivity and Power
  • Connection Types: 2.4 GHz wireless, Bluetooth, and Type-C wired
  • Bluetooth Version: 5.1
  • Bluetooth Device Name: Keychron K10 Wireless
  • Polling Rate (2.4 GHz and Wired): 1000 Hz
  • Polling Rate (Bluetooth): 90 Hz
  • Backlighting: 22 RGB backlight options
  • Battery: 4000 mAh rechargeable lithium-polymer battery
  • Wireless Battery Life (Backlight Off): Around 190 hours
  • Wireless Battery Life (RGB on): Around 100 hours at lowest brightness
  • Compatibility: macOS, Windows, Linux
Physical Specifications
  • Dimensions: 447.37 mm × 139.82 mm (17.61 × 5.50 in)
  • Weight: 1530 g (3.37 lb)
  • Height w/o Keycaps (front): 23.7 mm (0.93 in)
  • Height w/o Keycaps (rear): 29.8 mm (1.17 in)
  • Height w/ keycaps (front): 32.9 mm (1.29 in)
  • Height w/ Keycaps (rear): 40.1 mm (1.57 in)
  • Typing Angles: 3.43°, 7.26°, and 10.06°
  • MCU: ARM Cortex-M4 32-bit STM32F402 with 256 KB flash
  • Operating Temp: -10°C to 50°C
Additional Information
Author
with
Richard Witkowski
595 Reputation
5 Guides authored
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 131
All Time: 765
