Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
This is the Page for the Kenwood DRV-520 Dash cam. Here you can find troubleshooting to diagnose your problem, and guides to help you replace faulty parts if you need to.
Troubleshooting
Check out this device’s troubleshooting page:
Kenwood DRV-N520 Troubleshooting
Information
Manual Download (PDF):
http://manual.kenwood.com/en_contents/at...
Manufacturer’’s Website:
https://www.kenwood.com/usa/car/dashboar...
Specifications
Image sensor: 1/3 inch color CMOS
Recording Angles: Horizontal: 117 degrees, Vertical: 63 degrees
Lens: Wide-angle, F-number 2.0
Recording Resolution: Video max: 2.98 megapixels
Frame rate: 27fps
Recording Media: Micro SDHC card, 8GB-32GB (class 6 or more)
G-sensor Sensitivity: -4.0G to +4.0G (in .01 G increments)
Power Voltage: 14.4V (8.5 to 16V)
Current Consumption: 400mA
Temperature Range: -10C to 60C
Dimensions: W:79mm, H:22mm D:48mm
Weight: 77g (excluding cord)
Files:
Video:
  • Recording format: MOV
  • Video: H.264
  • Audio: Linear PCM
Image:
  • JPEG (max: 2304x1296)
2022 Kenwood Mobile Entertainment, Driver Assistance and Safety Catalog
Kenwood DRV-N520 Dashboard Camera Instruction Manual
Author
with
Austin Blakely
23,474 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 42
All Time: 1,429
