Guides
9 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
1.783-308.0
Background and Identification
The Karcher Saber Blade model 1.783-308.0 is a walk-behind, corded-electric compact floor scrubber released in 2017. The scrubber is designed to clean any type of hard floors, not carpets. Users can clean with adjustable cleaning pressure and several brush options. It features two counter-rotating cleaning brushes with variable pressure up to 88 pounds. The scrubber includes 2.5-gallon tanks for clean and dirty water and two squeegees for water pick-up in forward and reverse. Brush and squeegee removal does not require any tools.
The Karcher Saber Blade model 1.783-308.0 includes a 50-foot electrical cord and cleans a 16-inch wide path. It produces 1.5-horsepower and operators at a 71-decibel noise level. The scrubber’s brushes rotate at 660 revolutions per minute. It can hold up to ten liters of cleaning solution. Without any water or cleaning solution, the scrubber weighs 66 pounds.
The Karcher Saber Blade model 1.783-308.0 can be identified by its dark-grey body and yellow tank lid and handles. The cleaner is upright and includes handles that allow the user to walk behind the machine. It includes a large cover that hides the two water tanks. The manufacturer’s name, “Windsor,” is printed in bolded, blue capital letters below a stylized letter ‘W’ on a metal plaque just below the handles of the cleaner. The plaque also includes the name “Karcher Group,” also in blue font.
Technical Specifications
Technical Data:
  • Power supply (V): 110
  • Working width (in): 16
  • Drive Type: Corded
  • Cleaning solution capacity (l): 10
  • Dirty water container capacity (gal): 2.5
  • Operating noise level-std. mode (dB(A)): 71
  • Brush contact pressure (lbs): 88
  • Brush speed (rpm): 660
  • Weight (lbs): 66
  • Dimensions (L x W x H) (in): 20.5 x 18.5 x 15
Included Accessories:
  • 8.632-315.0 - Cord set, 14/3 SJT X 50 foot, yellow
  • 4.762-458.0 - Cylindrical brush red
  • 4.777-323.0 - Suction bar, complete replacement (BR 40/10)
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 39
All Time: 3,808
