Guides
7 Diagrams
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
BRC30/15C
Background
The Kärcher Carpet Cleaner BRC 30/15 C model is a compact walk-behind carpet cleaning machine that is intended for use on smaller areas or areas with difficult-to-clean surface contours, like the corners of a room. It is manufactured and sold by Alfred Kärcher SE & Co. KG, a family-owned business that sells cleaning equipment and systems.
Identification
The BRC 30/15 C model is one of three carpet cleaner machines sold by Kärcher. The other two models are the BRC 45/45 C and the BRC 40/22 C. Out of these three machines, the BRC 30/15 C is the least powerful, but also the smallest and most portable. It is liked by users for its sturdy construction and user-friendly features, as well as the uniform, reliable cleaning that it does.
Technical Specifications
  • Weight without accessories: 36 kg
  • Dimensions (L × W × H): 920 x 360 x 750 mm
  • Fresh/dirty water tank: 15 / 17 l
  • Turbine power: 1130 W
  • Brush motor power: 80 W
  • Air flow rate: 20
  • Vacuum: 300 / 30 mbar/kPa
  • Spray pressure, deep cleaning: 3, 5 bar
  • Spray rate, deep cleaning: 1 l/min
  • Working width, vacuuming: 315 mm
  • Area performance (deep cleaning/iCapsol intermediate cleaning): 150 m²/h
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 13,382
