Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Background
Johnson outboard motors are legacy marine propulsion engines associated with Johnson Motors, Outboard Marine Corporation, and later BRP-era service support. Many Johnson outboards share service practices, parts families, and identification patterns with Evinrude outboards from the same era.
Identification
Identify a Johnson outboard motor by the brand name on the engine cowling and the model or serial number plate on the transom bracket, swivel bracket, or clamp bracket.
Johnson outboards are commonly identified by the Johnson name or Sea-Horse badging on the cowling and a model or serial number plate on the transom bracket. Use the complete model code before ordering ignition, carburetor, water pump, or lower-unit parts.
Common Service Areas
  • Spark plugs, ignition, coils, and stator checks
  • Carburetor cleaning, fuel pump service, and fuel-line replacement
  • Cooling water pump impeller and thermostat service
  • Gearcase oil, propeller, seals, and lower-unit service
  • Control cable, shift linkage, and throttle linkage adjustment
  • Model and serial number lookup before ordering parts
Additional Information
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 79
All Time: 301
