Up to 20% off select tools
Documents
Jeep Cherokee KL Technical Specs
Engine and Performance
  • 2.4L Tigershark I4 (MultiAir2): The base engine for early models, producing 184 hp and 171 lb-ft of torque; noted for its unique electro-hydraulic variable valve lift system.
  • 3.2L Pentastar V6: A scaled-down version of the famous 3.6L, delivering 271 hp and 239 lb-ft of torque, providing a class-leading towing capacity of 4,500 lbs.
  • 2.0L Turbocharged I4: Introduced in 2019, this "Global Medium Engine" (GME) produced 270 hp and 295 lb-ft of torque, utilizing a twin-scroll turbocharger for improved low-end response.
Drivetrain and Transmission
  • 9-Speed Automatic (ZF 948TE): All KL models utilized this transverse 9-speed gearbox, featuring a wide 9.81 ratio spread to balance off-road crawling with highway fuel economy.
  • Jeep Active Drive Lock: Exclusive to the Trailhawk trim, this system includes a 2.92:1 low-range gear and a mechanical rear-locking differential for extreme articulation and traction.
  • Rear-Axle Disconnect: A technical highlight that automatically disengages the power transfer unit (PTU) when 4WD isn't needed, reducing parasitic drag and improving efficiency.
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 82
All Time: 528
