Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Device name: Jabra Speak 510 speakerphone
Model: PHS002W
Part of the Jabra Speak series, second to the Jabra Speak 810, the Jabra Speak 510 takes the conference room anywhere by transmitting phone conversations with crystal clear audio. Works with PCs and any Bluetooth-enabled devices. It has a compact and portable design in black and comes with voice guidance to keep you updated with who is calling, battery status, and more.
Features:
  • Connect via Bluetooth or USB, up to 100m wireless range
  • Rechargeable battery
  • Digital signal processing technology and wideband audio/HD voice
  • Built-in omnidirectional microphone
Identification
The Jabra Speak 510 is black and has a disc-shaped design. The Jabra logo is printed in silver on the top of the speaker. To confirm your device model, look for the label on the bottom of the speaker, which contains the model and serial numbers.
Technical Specifications
Dimensions
  • Weight: 6.8 ounces
  • Dimensions: 4.7 x 1.3 inches
Connectivity
  • Wireless Technology: Bluetooth 3.0
  • * Range: 100 meters
  • Auto-pairing capabilities
    • Can be paired with Bluetooth devices automatically
  • USB Connectivity
  • Multimedia Streaming Capabilities
    • Can stream music and audio from Bluetooth-enabled devices
Microphones
  • Omnidirectional
  • Mute Function Available
Speaker
  • 2 in.
  • Dynamic
  • HD Voice technology
    • Crystal clear sound without echoes or distortions
  • Built-In 3.5 mm jack plug
Battery Life
  • 15 Hours of Talk Time
  • Charge via USB
Additional Information
Jabra Devices for Cisco Unified Communications Product Overview
Jabra SPEAK 510 — Mode d'emploi
Jabra Speak 510 — Mode d'emploi
Jabra Speak 510 – Benutzerhandbuch
Jabra Speak 410 and Speak 510 Datasheet
Jabra Speak 510 User Manual
Jabra Parts and Accessories Catalog
Jabra Speak 410/510 Secure Mount Quick Start Guide
Jabra Speak 510 Manual de instrucciones
Jabra SPEAK 410 and SPEAK 510 Series Datasheet
Jabra Speak Series Datasheet
Jabra Speak 510 Portable USB and Bluetooth Speakerphone Datasheet
Jabra Speak 510 Portable Speakerphone Datasheet
Jabra Speak 510 Product Datasheet
Author
with
Jordan Murphy
784 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Spring 2016 Member of IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Members
48 Guides authored
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 181
All Time: 22,358
