Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Justfog Q16 Pro is a popular electronic cigarette (e-cigarette) that is known for its compact and portable design, as well as its ease of use and maintenance. The device utilizes a clearomizer, which is a type of e-liquid container, and a battery to vaporize e-liquid, which is then inhaled by the user.
The device has a built-in 900mAh battery and a 1.9ml e-liquid capacity tank. The 900mAh battery is known for its long battery life, which allows for extended use between charges. The device also has an easy-to-use, one-button operation, making it a great choice for both new and experienced vapers.
The device has a compact and lightweight design, which makes it easy to carry around and use on the go. It also features a childproof and leak-proof design, which adds to its safety and ease of use.
The device is designed for mouth-to-lung (MTL) vaping, which is a type of vaping that closely mimics the sensation of smoking a traditional cigarette. MTL vaping is popular among new vapers and experienced vapers who prefer a tighter draw and a more satisfying hit.
Specifications
Height: 70.4 mm
Width: 25.2 mm
Depth: 16.5 mm
Weight: 38g
Voltage: 3.5 - 3.8 - 4.1 - 4.4
Battery Size: 900mAh
Colors: Blue, Pink, Silver, Black
Author
with
dinoo_fixit
1,820 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 115
All Time: 4,976
